Gen 2 Leaf BMS Connectors and more
Posted: Wed Oct 28, 2020 4:00 am
I'm still in the hardware collection stage of my project and am trying to find BMS connectors.
I'm looking for either:
aftermarket connectors for the Gen 2 BMS (is Gen 1 the same?)
- 40pin sense lead connector to BMS
- 8pin temp sensor connector to BMS
- 16pin sense lead connector to BMS
Or a likely easier option, OE BMS wiring out of a Leaf
I found this thread, https://www.diyelectriccar.com/threads ... s.181297/ , in which Kevin Sharpe shares a few PDFs of the connectors he used, (attached for convenience). Though, he must not have needed all the connectors on the BMS.
Another question: I likely need to retain the temp and current sensor inputs on the BMS, do I need to source those components from a Leaf? or will a 3rd party component suffice?
thanks!
thanks!
