Page 1 of 1
Leaf gear box nismo LSD
Posted: Tue Nov 03, 2020 5:19 pm
by Bratitude
@Londonelectriccars post on Instagram, got a leaf nismo lsd from Japan. so I did some digging. And found this:
https://www.nismo.co.jp/products/nismo_ ... 19.html#a2
Fits ze0 and ze1 gearbox
And supposedly the Serena and Note.
** update 2022-12-07
looks like aus and nz folks can buy this directly from nismo japan.
https://shop.nismo.co.jp/collections/ni ... sd-ze0-ze1
Re: Leaf gear box nismo LSD
Posted: Wed Nov 04, 2020 8:28 am
by JaniK
Interesting
thanks for sharing
Posted: Sat Apr 09, 2022 11:53 am
by stuartd
Thank you that’s brilliant information trying to make a transfer box at the moment for four-wheel-drive system in a van but that might be just what I need
Posted: Sun Apr 10, 2022 8:18 pm
by Bratitude
stuartd wrote: ↑Sat Apr 09, 2022 11:53 am
I have replacement gear-sets in the works for the leaf gearbox, For this exact purpose!
sadly this nismo lsd is not the right kind for a 4x4 application, as it will not transfer torque when there is 100% slip. A ATB would be ideal, I’m taking measurements of the leaf diff to see if it a “standard “ Nissan diff,
Posted: Tue Aug 23, 2022 4:30 pm
by Tremelune
Has anyone ever...purchased one of these? My
FWD Mini is a one-wheel-peel monster and I'd rather like it to just accelerate...
And since Bratitude is watching, any shorter final gearing in the works...? Probably not useful to anyone but me, but 65mph is very busy in this thing with 20" tires...Stock is about 8:1...I think I need like 6:1...
Posted: Mon Aug 29, 2022 6:47 am
by Bratitude
Tremelune wrote: ↑Tue Aug 23, 2022 4:30 pm
I know a uk conversion shop has. Can’t recall whom. but you can buy them in Japan… so just need to find a dealer. Or weld the diff.
gear set is a 1:1 replacement for the intermediate gears, resulting in a 3.45:1…
Posted: Sun Sep 04, 2022 5:11 pm
by HawkHP+
Bratitude , If any future plan to make reduction to something like 6:1 I am in for one.
Posted: Sun Sep 04, 2022 5:48 pm
by Bratitude
HawkHP+ wrote: ↑Sun Sep 04, 2022 5:11 pm
if there's enough of a market for a set, ill look into it. im guessing for minis?
Posted: Tue Jan 31, 2023 10:17 am
by Bintang 5
Bratitude wrote: ↑Mon Aug 29, 2022 6:47 am
@Bratitude: on your homepage you mention 4,35:1 as ratio for the replacement gears.
Which one is correct?
Is there already a date when these parts are approximately goint to be available?
Posted: Tue Jan 31, 2023 1:36 pm
by SuperV8
Bratitude wrote: ↑Sun Apr 10, 2022 8:18 pm
Would be fine for a soft roader I would think - Audi Quattro used a Torsen centre diff (on the big longitudinal engined platforms like the Allroad/Q5 etc - not the transvers haldex system), and a Rangerover - though that is lockable, though it's quite capable before it need locking.
Agree if you plan on serious off roading/rock crawling not the best choice.
Posted: Wed Feb 01, 2023 1:37 pm
by monabuild
I have a good friend in japan that's in the JDM parts import/export business and im sure he would help get one of "nismo LSD" if someone is interested. If so please reach out and i can forward his contact info to ya..
Posted: Wed Feb 01, 2023 7:53 pm
by Bratitude
Bintang 5 wrote: ↑Tue Jan 31, 2023 10:17 am
4.35.
still a work in progress! but currently taking with a few different local gear shops. so hopefully soon!
monabuild wrote: ↑Wed Feb 01, 2023 1:37 pm
you can get them direct from nismo to Australia and some parts of EU it looks like now.
Posted: Thu Feb 02, 2023 4:27 pm
by Bintang 5
ok... thanks.
Was hoping it would be 3,45.
I am thinking about converting a small / light 4x4 car: a Suzuki SJ410 / SJ413 (Jimny/Samurai/Katana or whatever they were called in different markets).
I like the idea of getting rid of the combustion engine including gearbox and transfer case, and install the electric drive unit in place of the transfer case. I know the solution with the Tesla LDU including replacement gear and LSD, but a Tesla LDU would be complete overkill (regarding cost/power/torque) in such a small car, so a Nissan Leaf would be better. I think a Mitsubishi Outlander rear diff would fit even better than a Leaf, the "piled up" design of the Nissan Leaf Motor makes it somehow more challenging to fit under a car.
Anyway, considering Nissan Leaf with 4,35 reduction gear for my purpose:
With the stock Suzuki wheels (26") and the "longest" diff (3,7) I would end up with a maximum speed of only 74 km/h @ 10.500 rpm.
I could beef up the tires, but even with 31" I would "just" reach 100 km/h, but I want to use this car primarily onroad, so I don't think that such (relatively) large tires would be a good idea. I addition I am limited by the fact that I have to get the bigger tires road legal as well in my country.
How did you come up with the 1:4,35 ratio? Is this somehow given / constrained by the available space in the gearbox?
Posted: Thu Feb 02, 2023 4:40 pm
by Bratitude
Bintang 5 wrote: ↑Thu Feb 02, 2023 4:27 pm
i thought about the outlander gearbox aswell. but im not sure there's a big enough market to justify it
the intermediate gear to ring gear is 4.35. theres only enough room to fit a 1:1 from the input shaft to intermediate gear
Posted: Wed Jul 05, 2023 11:57 am
by olegil
No hope of changing the final ratio? 71:20 should be same centerline distance as 74:17, no? Or is there absolutely no chance of shrinking the final gear? I realize there would be less splashing of oil, though. Maybe not a good idea.
And does your replacement gears fit both the EM57 and EM61 gearboxes?
Posted: Wed Jul 05, 2023 5:01 pm
by Zieg
6:1 gears does sound appealing for light cars though. I may find i have more torque than I can use with my build, and if that's the case it'd be nice to be able to gear up a bit. The goal being to extend the flat part of the torque curve as much as possible.
Posted: Wed Jul 05, 2023 7:06 pm
by Bratitude
olegil wrote: ↑Wed Jul 05, 2023 11:57 am
you could, it would just start getting very expensive.
the goal is to have it work with both gearboxes \
