Ampera CAN bus / where is BMS traffic?
Posted: Sat Nov 14, 2020 1:06 pm
by clanger9
I have a dumb CAN bus question:
I have connected my Due board to the OBD2 port on my car and I can see the CAN traffic in SavvyCan. Thousands of frames/sec. Yay.
However, I don't see any BMS frames (0x460, 0x470, 0x7E0 etc). Where are they? Do I need to connect to a different CAN bus? I was under the impression that all CAN traffic appears on the OBD2 port.
Re: Ampera CAN bus / where is BMS traffic?
Posted: Sat Nov 14, 2020 4:58 pm
clanger9 wrote: ↑Sat Nov 14, 2020 1:06 pm
Well BMS (BECM master) is located inside battery and communicates with BICMS (slaves) at 125kbaud CAN.
BECM in turn relays its data to HPCM2 module which is a decision maker for BMS, charger and battery heating/cooling. That uses 500kbaud lines. There are 2x 500kbaud lines in Ampera and there are two obd2 ports in Ampera. Try the wiring schematic from GM.
Posted: Sat Nov 14, 2020 5:18 pm
by clanger9
Thanks - I hadn't appreciated the CAN buses were arranged hierarchically. I have the GM manual here so I will have a bit more of a read...
Posted: Sat Nov 14, 2020 6:08 pm
by clanger9
I found a bit more info. Apparently, the four 500kbps CAN buses are brought out onto different pins on the two OBD2 connectors:
Driver's side:
6(+) 14(-) onstar, parking brake, fuel pump, brakes, both drive motors, Engine control, HV drive electronics, AC compressor
12(+) 13(-) brakes, both drive motors, Engine control, HV drive electronics, accelerometer, steering
Passenger side:
12(+) 13(-) both drive motors, Engine control, HV drive electronics, 12V inverter
3(+) 11(-) HV battery charger, HV battery electronics
I will try running a capture on some different pins...
Posted: Sat Nov 14, 2020 7:53 pm
clanger9 wrote: ↑Sat Nov 14, 2020 6:08 pm
Passenger side:
There you go. 3 and 11 are then.
Posted: Sat Nov 28, 2020 2:32 pm
by clanger9
So, another n00b question: do I have to issue CAN bus commands to the OBD2 port to get the BMS to respond for each module?
I see frames on pins 3/11 from BMS module 1 (0x460) every 250ms, but nothing for the other modules (0x470, 0x461 etc.)
I had assumed I'd see traffic from all the modules, not just the first one.
What am I missing? Do I need to sniff the BMS bus directly to see these frames?
Posted: Sat Nov 28, 2020 3:21 pm
That is BECM communicating with HPMS2 module. BICMs are connected on the CAN bus inside battery case. 125kbaud Can does not go out of the battery.
Posted: Sat Nov 28, 2020 3:33 pm
by clanger9
OK ta, that would explain it. So, follow on question: can I get cell voltages over the OBD2 port?
Do I need to send secret/undocumented CAN messages to say "Get me cell1 voltage" etc?
