Page 1 of 2
Tesla CAD Models
Posted: Wed Apr 24, 2019 9:18 pm
by Kevin Sharpe
CAD models for the various Tesla parts starting with the Model S/X Small Front Drive Unit
3D Scan files on GrabCAD (
here)
Re: Tesla CAD Models
Posted: Wed Apr 24, 2019 9:24 pm
by Kevin Sharpe
Model S/X Large Rear Drive Unit.
3D Scan Files on GrabCAD (
here)
Posted: Wed Apr 24, 2019 9:27 pm
by Kevin Sharpe
3D Model on GrabCAD (
here)
Posted: Wed Apr 24, 2019 9:47 pm
by Kevin Sharpe
Model S/X 5.3kWh Battery Module
here)
Posted: Sun Apr 28, 2019 9:49 pm
by jon volk
I used the LDU on my build. Dimensions were perfect.
Posted: Thu Oct 24, 2019 9:33 pm
by Kevin Sharpe
Tesla Gen 2 On Board Charger
here)
Posted: Thu Oct 24, 2019 9:50 pm
by Kevin Sharpe
Not sure about the naming convention
Tesla Model 3 Passenger side inboard battery module
https://grabcad.com/library/tesla-model ... y-module-1
Tesla Model 3 Passenger side outboard battery module
Tesla model 3 battery module - short passenger side outboard
https://grabcad.com/library/tesla-model ... outboard-1
Posted: Tue Feb 04, 2020 11:33 pm
by Kevin Sharpe
Posted: Mon Feb 24, 2020 11:17 pm
by Paerel
Hi, I have a 3D scanner and providing a scanning services. I can scan almost any part for free for this community. I just need a part to do it. I’m local in Miami, FL. Let me know if I can help you somehow ;
Posted: Wed Mar 11, 2020 8:44 pm
by woutvangerven
Two thigs:
-There is a naming error on grabcad:
Tesla model 3 battery module - short passenger side outboard = Tesla model 3 driver side outboard battery module
-and here is the 4th module:
Tesla Model 3 Drivers side inboard battery module
Posted: Fri Mar 20, 2020 10:36 pm
by cloudy
Time to contribute something back. I could only find scans of the front SDU - so scanned and uploaded my rear one here
GrabCAD
It's photogrammetry rather than laser, but It should be accurate within a few mm - but there was some obfuscation around the mounts due to the hoist straps...
Posted: Sat Mar 21, 2020 12:59 pm
by Kevin Sharpe
cloudy wrote: ↑Fri Mar 20, 2020 10:36 pm
Fabulous, thank you
Posted: Sun Mar 22, 2020 10:50 am
by Kevin Sharpe
Model S/X Battery Pack.
Two 3D Models on GrabCAD (
here) and (
here)
Posted: Sun Mar 22, 2020 6:18 pm
by 57 Chevy
Just a note to say don't trust the accuracy of some models, +/-20mm would be a good margin of error. There is a full Model S on Grabcad but it isn't suitable for mockup as it is.
Posted: Mon Jan 04, 2021 6:25 pm
by New Electric Ireland
Posted: Sun Feb 28, 2021 4:52 pm
by EV_Builder
GrabCAD
Can you tell me the scaling? It looks way off. If i measure in the grabcad vieuwer distance between 2 mountingpoints is 0.55mm Cant be right?
I would like to have the stp if you can generate it? Or IGES?
Posted: Sat Mar 13, 2021 7:56 pm
by EV_Builder
Ok so i ended up installing "blender" (see blender.org).
With Blender you can import the OBJ files and modify the mesh to be more relaxed.
This smooths out allot of unneeded and wrong detail.
Also you can easily scale the OBJ part with blender.
You can then export to STL file.
Then with FreeCad you can import the STL and do an conversion to IGES for example, but perhaps your normal CAD program can also import STL already.
Posted: Fri Apr 02, 2021 1:00 pm
by muehlpower
I made a drawing of the GEN3 charger. It is not very detailed, but the dimensions are correct.
Posted: Mon Oct 25, 2021 7:56 am
by muehlpower
On ebay classifieds someone sells an LDU dummy to make brackets and check the space!
Posted: Wed Sep 21, 2022 2:09 am
by jason_arnold
Link to the dummies in case any is looking (seems to be German only):
https://www.ebay-kleinanzeigen.de/s-anz ... 4-223-3982
Posted: Wed Sep 21, 2022 5:13 pm
by nilsvr
They now are liste for almost 400€ did anyone in Germany or surrounding already buy an LDU model?
I would happily rent yours out for a while to fit my mounts.
Posted: Sat Jan 07, 2023 3:07 pm
by JockE28
Anyone got the scaling on this one? or exact measurments between monting point etc?
Posted: Sat Jul 01, 2023 9:24 pm
by 52I
Grabcad is no more, all files have been deleted according to their blog.
Any chance somebody has a Model 3/4 motor CAD files stored somewhere else?
Thanks,
Mark
Posted: Sun Jul 02, 2023 6:34 pm
by P.S.Mangelsdorf
52I wrote: ↑Sat Jul 01, 2023 9:24 pm
Thanks,
Mark
Grabcad appears to still be up for me.
Posted: Sat Jul 15, 2023 4:05 am
by Mitchy
Grabcad works for me as well.
Just uploaded the Tesla Model S - Raven front drive unit scan:
https://grabcad.com/library/tesla-model ... ive-unit-1
