Wanted leaf 24kW battery pack.
Posted: Sat Apr 24, 2021 8:31 pm
by 36320e
Long shot, i know. I am looking for a battery pack, BMS, Charger and charge port and cabling from a nissan leaf to finish my conversion. Ideally from Ireland. I said i would ask on here first before going further afield.
I would also concider all of the above from other makes.
Re: Wanted leaf 24kW battery pack.
Posted: Sun Apr 25, 2021 3:42 pm
I do plan to swap my 24 kWh pack for a 40 kWh pack and it would be left over. Cells, interconnects, BMS cabling, BMS, current sensor, service disconnect. No charger and charge port though.
Ok, this is Germany not Ireland and I don't quite know when this will happen.
Posted: Sun Apr 25, 2021 9:13 pm
by paaa
I have a 3kw and a 6kw gen 1.5 charger , I should have a charge port cable. PM me and I can send you some pics on what else is there.
Posted: Tue Apr 27, 2021 12:45 pm
by 36320e
johu wrote: ↑Sun Apr 25, 2021 3:42 pm
Thanks for your reply. Let me know when you are ready.
Posted: Thu Apr 29, 2021 10:47 pm
by Extremetaz
36320e wrote: ↑Sat Apr 24, 2021 8:31 pm
I have a BMS here for sure.
Might have some cabling... think I passed the best of it to Alibro though.
Have about a half a pack's worth of modules and all the bus bars etc.. still on the shelf here with about 56Ah capacity in them according to Leafspy at the point of removal (last march when I did my own 40kWh swap).
Pretty sure there's a contactor block there too.
Definitely have a couple of the main pack connectors, and a Type1 charge port which I've been using for charger diagnostics.
Posted: Fri Apr 30, 2021 9:00 pm
by 36320e
Extremetaz wrote: ↑Thu Apr 29, 2021 10:47 pm
Thanks for your message. I have sent you a PM.
Posted: Sat May 01, 2021 11:59 am
by 36320e
36320e wrote: ↑Fri Apr 30, 2021 9:00 pm
Is your pm inbox full. Message i sent you is still in my outbox.
Posted: Sat May 01, 2021 5:44 pm
It means he hasn't read this yet.
Another thing: can you please quote more precisely, not dump everything in.
Posted: Sat May 01, 2021 7:09 pm
by 36320e
Ok. Thanks.
