what is max battery nominal voltage for leaf inverter?
Posted: Sat Jun 26, 2021 8:08 pm
by papasapien
so the controller is in the leaf inverter right? what is the max battery voltage i can use?
Re: what is max battery nominal voltage for leaf inverter?
Posted: Tue Jun 29, 2021 8:56 pm
by Bratitude
the em57 Gen2 Inverter igbt’s and capacitor are rated at 600v.
I wouldn’t go over 500v
Posted: Fri Jul 02, 2021 6:31 pm
by papasapien
Bratitude wrote: ↑Tue Jun 29, 2021 8:56 pm
504 max voltage from a 120s pack should be good then right?
good 444v nominal. Just to make the motor spin faster?
Why doesn’t anyone do this already?
Posted: Fri Jul 02, 2021 7:32 pm
by Bratitude
papasapien wrote: ↑Fri Jul 02, 2021 6:31 pm
I don’t see an issue. Just don’t want voltage spikes over the rated values.
Not so much “faster” but more power yes.
it requires more work on the battery management side of things, as most packs are 96s. You would have to make or get a bms that can manage 120 cells.
Also not a lot of obc available can output 500v.
