Field weakening & gearboxes
Posted: Wed Jul 07, 2021 10:17 am
I have moved on to the over thinking stage of planning
I have an outlander rear motor (with gearbox diff thing) a Prius inverter (plus a Yaris spare) and the project car 1999 mx5).
Due to life circumstances (moving house) I am only able to bench test stuff at the moment, but I'm trying to 'get my ducks in a row' .
I have been working on BMS stuff with bigpie, but now I really want to get something spinning even if it can't go in the car yet.
Originally I was planing to do the most frowned upon thing in this forum.... Use a clutch!
Now am realising that this is probably very stupid idea.
Gearboxes for mx5are about ÂĢ40 so insanely cheap... Based on johu's recent video about energy effiency between gears and bextenders pain of field weakening...
I was wondering what are the real world power losses in field weakening?
What I'm thinking is can I remove unused gears from the gearbox (5th, and reverse look easy based on teardowns of mx5/rx7's).
Can I weld the gearstick in second gear as that would give me 80mph at 9000rpm at my current diff and gearbox. Would look cool wulity the zero ev r n d switch
Originally with an 80s and OEM inverter the torque curve goes flat at 3000-6000rpm, which makes me suspect the field weakening point is about 4500rpm similar to the leaf ... Using a 96s would push this up a little...
Is there likely to be much power left at 7000-9000 rpm?
What I would like is good acceleration upto about 70, beyond that becomes a little academic due to the wall of air sapping my precious battery
I know that the real answer is just build it and decide if 2nd or 3rd is best, 3rd would technically give me a top speed of over 100mph which I don't need acceleration is the target.
Just wondered if there was any real world data or experience to analyse/think about
