Page 1 of 1
Resolver Excitation Power Question
Posted: Wed Jul 03, 2019 11:39 pm
by ChazFisher
Johannes, I see in the Rev 3 schematic you've added a small boost converter to raise the power supplied to the resolver excitation circuit to 15 V. Was there an issue with your original resolver circuit used with the Rev 1/2 boards, which was simply powered from the 12V power input?
Thanks.
Re: Resolver Excitation Power Question
Posted: Fri Jul 05, 2019 9:07 pm
by johu
I wanted to be independent from the auxilary voltage, thats all. Now you can power the inverter from just 5V if you so wish and it runs. Also I changed voltage to 9.5V instead.
Posted: Sat Jul 06, 2019 7:29 pm
by ChazFisher
Sounds good, thanks!
