best way to build a 2170 or 4680 pack 4 a first gen Roadster?
Posted: Wed Jul 28, 2021 1:31 am
Hi.
Trying to get a good deal on a Tesla Roadster with a solid pack. I hope to find a good deal on a Roadster witH a bad battery or PEM. The OEM cells are older than their design life. One possibility is to buy Tesla's 3.0 upgrade for 29k plus 5k to get a rebuilt PEM. In addition to the high cost, I think that building a pack from either structural slabs of 4680's or pieces of 2170 modules could be done for much less than 30k. I think that doing that pretty much means dumping he PEM, which is a pain but not only does doing that make it possible to us the most cost effective cells available to today but it will make it much simpler,to replace either individual cells or the entire pack in the future.
Main reasons for choosing the 4680 structural packs is that I believe that dividing the pack into self-contained chunks will be relatively easy and on 6-18 month's I think they will be the least expensive.
I can't do this project myself, (health issues). I'm trying to come up with a plan that EV-West or some close friends can implement for about 10k-30k that will be better than the 3.0 package.
NOTE:
Posted by @X.l.r.8 on another forum:
Thanks! I think a sawzall or a bandsaw might work. Depends on if the cells are touching. If not switch to 2170's.Taking apart a structural battery pack will be inherently challenging. The whole point is that there is structural adhesive holding all the cells together so that they act as a solid structure. Take a look at the Model 3 modules and how hard they are to take apart without damage. Now imagine that there are no modules and the whole pack is bonded together.
NOTE:
Would the MP3 motor be easier to control than the OEM motor? How difficult to mount? The most fun would obviously be either one new MS carbon wrapped motor that weigh 30 lbs. and can put over 400hp or the complete dual motor rear drive system with torque vectoring.
background so I understand the desire to build concept. Head over to open inverter. That’s where we are doing exactly this. The car itself makes little difference as you will see. Using a model Y battery may not be the ideal once you read through the battery threads. The simp bms controls pretty much all BMB’s so you can use what you like. The Prius/leaf and Tesla model s and 3 have been pretty much decoded and have can codes for pretty much all the components, even DC charging. Not sure why you would subject this to a roadster, but then I had a V8 in a 924 CGT so who am I to judge.
I don’t know what the saturation point is for a roadster motor is, but the fact they are hand wound for the sport and the temperature it climbs to on 200 mile drives, showed it’s pretty close to max. If you could push the max voltage rather than increasing the amps, then find a way to get some better cooling. Again, at that point I think a M3P motor would be a much better option. Built in inverter, throw a Gen 2 48A charger, a volt 12v DC converter and you could have quite a package. Again stopping it may be problematic. The weak point of the roadster is the brakes, it was a primary reason I went to the Porsche platform for my model S performance motor.
To your point the 3.0 gives more range, that’s it, the 3.0 does not charge quicker so the range is hindered by the increased charging time, something model 3 owners fail to understand. If you are charging for 6 hours for a 2.0, the 3.0 will take 9 hours. So unless you can reach your destination in one go, the 3.0 is basically bragging rights. The modern pack will need cooling? And that’s controlled via the PEM. There goes the HVAC, I’m not seeing any improvement, it’s no longer an integrated package. You may improve range, but that’s one metric, knowing the roadster is one of the most efficient vehicles, period, you are going to have to do something amazing to ‘improve’ on the original in all areas, making it go faster is easy.
