Mounting motor/inverter/PDM separately...
Posted: Thu Aug 12, 2021 8:38 pm
by Greenbeast
Can someone point me to any projects where the leaf stack components were separated and mounted independently?
Re: Mounting motor/inverter/PDM separately...
Posted: Sat Aug 14, 2021 9:00 am
by Greenbeast
Interested because I'm wondering if I could mount the inverter and charger forward of the motor and leave a nice large, square area for batteries/HVJB above them all
Posted: Sat Aug 14, 2021 2:36 pm
by earthman
it is dangerous to put batteries in the front, in case of an accident they will be damaged, instead of a gas tank and a silencer. and the center of gravity is lower
Posted: Sat Aug 14, 2021 2:46 pm
by celeron55
I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
Posted: Sat Aug 14, 2021 5:32 pm
by zippy500
looks really smart, does anyone know how to control the Charger/DcDc unit ?
Posted: Sat Aug 14, 2021 5:47 pm
by Greenbeast
earthman wrote: Sat Aug 14, 2021 2:36 pm it is dangerous to put batteries in the front, in case of an accident they will be damaged, instead of a gas tank and a silencer. and the center of gravity is lower
Yes I've read that before, I've also seen plenty of batteries put up front
Posted: Sat Aug 14, 2021 6:10 pm
by Greenbeast
celeron55 wrote: Sat Aug 14, 2021 2:46 pm I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
Nice one, thanks for putting the pictures here for me
Posted: Sun Aug 15, 2021 12:04 pm
by Alibro
Do you already have the motor and inverter?
Posted: Sun Aug 15, 2021 12:39 pm
by Greenbeast
Alibro wrote: Sun Aug 15, 2021 12:04 pm Do you already have the motor and inverter?
No, I don't
Posted: Sun Aug 15, 2021 1:03 pm
by Alibro
If you get the Mk1 Leaf motor and inverter they are already separated. The leads are around 30cm long.
Posted: Sun Aug 15, 2021 1:12 pm
by Greenbeast
Ah, thanks!
Posted: Sun Aug 15, 2021 1:28 pm
by Alibro
This my the motor removed from the donor Leaf and you can see the Inverter lead on the top.
