Aixam mega van repair and upgrade
Posted: Tue Sep 21, 2021 9:33 am
Hello Everyone
Just introducing my project its an aixam mega van! "mega" like the "super" in a suzuki super carry.
its a small (hideous acording to my partner) electric van.
this van is a salvage from london where as per the standard the batteries have been stolen...
The orginal plan for me was get nissan leaf battery split cells for 48 volts and install in place of stolen battery.
but on closer inspection the battery relief team decided the loom was in the way and went clean through it so now im rewiring the whole thing
so my now renewed plan. is as follows (in no particuar order)
remove all wiring
remove controller, DC-DC, ecu, dc motor and gears
repair the bodywork on the cab (split plastics everywhere you look)
rebuild the floor and seat in the cab
install 200-250v worth of nissan leaf battery
install gen 3 prius inverter converter (with drop in logic board)
install rav 4 rear diff motor (in the front and splice the cv shafts to fit)
remove the van box
build a flatbed capable of carrying a motorcycle
rewire everything
build a new dash for all the new stuff
terrify myself on how shocking the brakes are
I have got the nissan leaf battery collected it yesterday getting it out of my van was a mission in itself
a combination of a jack under one end to allow the pallet to roll out my van a pair of steel square tube supported on axle stands to slide the pallet out on and a chain hoist to take the weight once out the van.
naturally as soon as the chain hoist had the weight the pallet shifted and knocked the bars and axle stands over
and yes I built my son's swing to also be a gantry crane... it was orignally built to lift an engine out of an ldv convoy
remove all wiring
remove the van box
rewire everything
