VW Lupo with Prius Gen2 transaxle
Posted: Thu Oct 14, 2021 8:11 pm
So, this thread is more of a question than an announcement :)
2 years after finishing the Touran I feel like getting my hands dirty again. No, I do not need another car, the whole endeavour is entirely pointless but I still want to do it.
We are looking into a budget simplicity conversion. I want to use the Prius transaxle with MG2 only and use the other inverter for charging. I want to go VCU-less despite the car having a CAN bus. I assume it's the same one as in Touran. The car has no climate control and no power steering, so more simplicity there.
I will try to fit the 24 kWh left over Leaf pack although I'm afraid that it is too large. Not sure if I'll stick with the centralized Leaf BMS because the battery will probably be all over the place.
Charging will be Type-2 only, I hope the Prius converter will sport 22 kW.
So, the only question: should I take it on or am I wasting my time? :P
Re: VW Lupo with Prius Gen2 transaxle
Posted: Thu Oct 14, 2021 8:22 pm
by LRBen
I might have a bias view given I'm using the same inverter with plans to use MG 1 as a charger as well. But I think it is a great idea!
Posted: Thu Oct 14, 2021 9:24 pm
by Ev8
Awesome the son of a guy I work with has a Lupo and a mk2 polo breadvan and I keep saying can we put a Prius transaxle in one of one of them
Posted: Thu Oct 14, 2021 9:53 pm
by Markos
My old university converted a Lupo 3L to electric. They probably have some papers online with lots of information about it.
A quick google search gave me this website (I didn't read it, I don't have much time atm). Despite being an old page and the specs might be outdated, its a good start for looking for more information:
https://www.greencarcongress.com/2011/0 ... 10409.html
If I remember correctly, the Lupo had a lot of favorable hardware because the Lupo was a showpiece of Volkswagen about efficiency. I think a lot of hardware was accessible/readable. I'm not sure if this is for all Lupo's or only the 3L. But I should say that a Lupo with a Toyota Transaxle sound really nice.
Posted: Thu Oct 14, 2021 10:01 pm
by Markos
Posted: Fri Oct 15, 2021 4:48 am
Markos wrote: Thu Oct 14, 2021 9:53 pm My old university converted a Lupo 3L to electric. They probably have some papers online with lots of information about it.
They were my inspiration on how to squeeze LiFePos into smallest of places back in 2013. They managed with 27kWh which is similar to VW original UP.
Also dont forget to add in a heating system. Heater is mandatory.
And i still recommend small single phase charger. 1ph buck/boost charging is terribly inefficient. And most of the time you dont need really quick charging from 3phase. Well untill you do... 8-).
Posted: Fri Oct 15, 2021 5:18 am
by bexander
johu wrote: Thu Oct 14, 2021 8:11 pm So, the only question: should I take it on or am I wasting my time? :P
Well, that depends on what you would do with your time instead?
I think it is always fun with new projects so I vote, go for it!
Want to keep it really simple?
If you make the car light enough and with some modification you can run without brake booster.
Regarding heater, it is not necessary to be able to heat the entire cabin but you need to have a windscreen demister. I run a 750W PTC air heater element for this purpose, works but on the weak side.
Posted: Fri Oct 15, 2021 8:58 am
Thanks for so many comments :) That is interesting they fitted so much energy with LFP.
I think I will use the 4-channel BMS so the conversion should certainly help its further development. Right now I'm not using the BMS, that's by there is no progress...
Posted: Fri Oct 15, 2021 9:34 am
by m.art.y
johu wrote: Fri Oct 15, 2021 8:58 am I think I will use the 4-channel BMS so the conversion should certainly help its further development. Right now I'm not using the BMS, that's by there is no progress...
I'm sure quite a few people are interested in using 4-channel BMS including myself. Would be a good motivation to work on it. Also time spent doing what you like is never wasted.
Posted: Fri Oct 15, 2021 9:41 am
Can you make your BMS talk CAN in a standard way that would allow use of other equipment with it? For example CAN display, inverter etc...
Posted: Fri Oct 15, 2021 9:52 am
arber333 wrote: Fri Oct 15, 2021 9:41 am Can you make your BMS talk CAN in a standard way that would allow use of other equipment with it? For example CAN display, inverter etc...
Yes, it has 2 CAN ports that are freely configurable like on the inverter.
m.art.y wrote: Fri Oct 15, 2021 9:34 am I'm sure quite a few people are interested in using 4-channel BMS including myself. Would be a good motivation to work on it. Also time spent doing what you like is never wasted.
Good point :)
Posted: Fri Oct 15, 2021 7:57 pm
by LRBen
+1 on the BMS front as well! I should be getting my isolator boards through soon then I have some stm32 transplanting to do.
Posted: Fri Oct 15, 2021 8:31 pm
by RetroZero
In terms of the transaxle, I have found it heavy for the golf one. If you have to stick to original manufacturer weight, I would remove insides of MG1. Depends what you want to do with it... Autonomy or speed.
Posted: Fri Oct 15, 2021 9:20 pm
by celeron55
Q211 MGR, obviously.
Posted: Sat Oct 16, 2021 4:36 am
by bexander
celeron55 wrote: Fri Oct 15, 2021 9:20 pm Q211 MGR, obviously.
+1 :)
Posted: Sat Oct 16, 2021 12:33 pm
by Markos
Deleted
Posted: Sat Oct 16, 2021 6:22 pm
by MattsAwesomeStuff
Deleted, offtopic.
Posted: Sat Oct 16, 2021 6:25 pm
johu wrote: Thu Oct 14, 2021 8:11 pmSo, the only question: should I take it on or am I wasting my time? :P
If I was in your shoes, I would think it would be healthy to somewhat annually convert an EV. It keeps your context fresh in your mind about what the challenge is and how to make it go smoothly.
In any case, anyone converting and documenting anything is never a waste of time for the rest of us.
Posted: Sat Oct 16, 2021 8:58 pm
by Markos
MattsAwesomeStuff wrote: Sat Oct 16, 2021 6:22 pm
Markos wrote: Sat Oct 16, 2021 12:33 pm(I don't hope this is too much offtopic, I'm trying to understand what you want to do and how it works)
Well... entirely offtopic. This is Johanne's build thread for a specific project, not a general "troubleshoot for me how to use a Gen2 Prius transaxle" thread.
There are threads about that, this is not that. Though perhaps an admin could move your post to one of those instead.
I extended my post a bit too much while typing. It was initially about WeberAuto mentioning the Gen2 transaxle can't be used for EV only (in their original purpose of course) because of overrevving MG1 (this part of the video 1:12:45). I thought it might be an interesting part of the video. But I agree, the post ended up to much offtopic so I've deleted it.
Posted: Wed Nov 10, 2021 4:39 pm
Looks like the project is morphing into this, so will continue here:
viewtopic.php?f=11&t=650
