Prius PHEV BMS hacking - bigger battery?
Posted: Sun Oct 24, 2021 6:25 pm
we have a 2012 Prius PHEV - the vehicle works very well, but the battery is very small. It would be an easy job to upgrade the batterys to some with a higher capacity, but the problem is that the bms has the capacity programmed in and adding a bigger battery won't make a big difference therefore. At least that's the information one can find on the internet.
Does anyone know something about if there is a work around? Any input is apprechiated!
Thanks, Philip
Thanks, Philip
