Ethernet instead of WiFi
Posted: Fri Dec 10, 2021 6:24 pm
On the back of a conversation around the flakiness of WiFi I did a little experiment to see if there was a simple way to add ethernet to an OI board. Turns out there is!
Olimex do an esp32 board which includes an ethernet port.
@0xBedz has already implemented an esp32 version of the firmware. I took this, added a couple of tiny tweaks to enable ethernet and it appears to be working.
Code is over in Github here.
I started writing up some info in the wiki here.
This is also good for paranoid people like me who don't want their car accessible over WiFi
To do
To do
- See what the power consumption of the board is to see if it can reasonably powered by the OI board.
- Right now, the ethernet port comes up as a DHCP client. I'll see if there is a simple way to have the board act as a DHCP server. This might be a more intuitive way for people to use it. I.e., plug in laptop, laptop acts as DHCP client, gets IP from esp32 board.
- It has a few serial ports. I'd like to use one of these modules in my two-brain, dual-motor Prius board so I can access both brains easily at the same time. This might necessitate extending the web interface so it knows how to deal with more than one serial port.
- I have a WT32-ETH01 board on its way to me as well. I'll see if I can get this one working too. It's a bit smaller, so might be handier.
