Main relay opening when throttle signal
Posted: Fri Dec 31, 2021 8:13 pm
by qmedia2651
My main relay is cutting off when sending throttle signals.
341 dc at battery pack
Udc = 416v
Udcsw set to 80% of 341 =275v
BMW E46 pedal
Tesla SDU Logic board v5 open inverter organization board.
Every thing okay except cuts off my main relay.
Some times the motor makes a sound to spin
Any body had this problem before.
Please advise. Thanks
Re: Main relay opening when throttle signal
Posted: Fri Dec 31, 2021 10:38 pm
qmedia2651 wrote: ↑Fri Dec 31, 2021 8:13 pm
Is it possible voltage measurement would drop so low inverter would open contactor? Or raise reference above GND?
Try setting UDCSW voltage set to 60Vdc. Maybe that would cure the problem. Also try to record the graph of UDC measurement when applying throttle. You may find out your problem is voltage reference on the STM32 chip.
Posted: Sat Jan 01, 2022 10:07 am
Nope, undervoltage does not open the contactor.
It is most likely an overcurrent event or desat. What are your parameters? Please attach json file that you can download from the web interface.
Personally I'd raise udcsw to 320V or so.
Posted: Sat Jan 01, 2022 3:05 pm
by qmedia2651
Here is the Parameter file.
Posted: Sat Jan 01, 2022 3:11 pm
by qmedia2651
Johu here are some pics of the web parameters
with no voltage applied.
Re: Main relay opening when throttle signal [SOLVED]
Posted: Sat Jan 01, 2022 3:30 pm
You have default parameters loaded, please use the "Download File" button here:
https://openinverter.org/parameters/view.html?id=15 and then the "Upload parameters" on you web interface. Then save to flash. I'm guessing something in the configuration makes it trip.
Posted: Sat Jan 01, 2022 3:36 pm
by qmedia2651
OK Johu thanks a lot will do take care.
will try this out.
I am using V5.14R
Posted: Sat Jan 01, 2022 4:13 pm
by qmedia2651
Johu !! good news uploaded the parameters calibrated the throttle and WOW I hit the throttle to much the motor lifted from the front and knocked my level off.
Motor is working Thanks a lot goanna have to Patronize for the good help and learning.
Thanks very one.
Posted: Sat Jan 01, 2022 4:46 pm
Great
Posted: Sun Jan 02, 2022 12:36 am
by qmedia2651
GOOD WAY TO START THE YEAR JOHU !!!!!!!!
