1972 Honda Z600 2019 Leaf conversion
Posted: Thu Mar 24, 2022 5:12 pm
by Z600EV
Hello all,
I wanted to start a thread to document my conversion on my 1972 Honda Z600. I'll post pictures later. I purchased a complete 2019 Nissan Leaf motor assembly from top to bottom with all harnesses. What I realized too late was that the inverter for the 2019 model is not the same as the previous Gen 2s, so the adapter board from the Leaf Gen 2 kit does not work. I have the means to have a new adapter board made (I will offer to others) and I was wondering if anyone has access to the pinouts to the connector on the left? I'm hoping that the connections are the same and just a different layout.
-Ed
Re: 1972 Honda Z600 2019 Leaf conversion
Posted: Thu Mar 24, 2022 7:21 pm
Actually a design exists for the Gen3 inverter but it is in some awkward format and I'm not even sure it was published here. Maybe Kelju chimes in.
Posted: Thu Mar 24, 2022 11:42 pm
by Z600EV
I was think about just rewiring the internal harness to connect to the Gen 2 adapter board and just hardwire the external connector pigtail to the Gen 2 adapter board.
Unfortunately the Gen 3 DC/DC converter and charger are too tall for my application so I’ll have to come up with an alternative. I would like to repurpose the lower unit to get a clean connection with the inverter.
Anyone interested in a complete Gen 3 upper half? I live in the Melbourne FL area.
Posted: Sat Mar 26, 2022 2:46 am
by Z600EV
Can anyone confirm if this mine is a 160KW inverter? I believe it is from Dala’s video on his upgrade. I believe the “N” signifies it’s a 160KW.
Posted: Fri Apr 08, 2022 4:09 am
by sewliothewise
No way! I'm working on an
N600 (1971) with a Leaf (EM61). Looking forward to seeing more details on this one (I assume we'll be solving a lot of the same problems).
Are you using the leaf wheel hubs or the original Z wheel hubs? And any thoughts on added/edited suspension (still haven't landed on anything solid)? Where are your batteries going?
Psyched to see another early Honda on here. Good luck, man!
Posted: Tue Apr 12, 2022 4:01 pm
by Z600EV
Hey, very cool to hear you're doing one too! I'm going to try and use the stock hub but I may machine new ones to accept a stronger axle end, we'll see. I was going to try and modify the stock subframe to work but I ended up scraping that Idea and slociviccoupe on this forums is helping me build a tubular subframe from scratch. I'm hoping to have the subframe done by the end of the month and then I have to deal with the steering rack. I have to raise and rotate it to clear the leaf gearbox. I'm going to have to machine off the mounting tabs and use a tube clamp setup to make it work. As for suspension, they make a coilover kit that I plan to use with custom springs. The rear may get a custom IRS setup.
