Page 1 of 2
Small drive unit inverter teardown and repair
Posted: Sun Apr 03, 2022 2:54 am
by js1tr3
I got the plastic and goo off, but can't figure out how to get past to the power stage.
I fried two legs.
http://www-personal.umich.edu/~siegeljb ... 223414.jpg
Re: Small drive unit inverter teardown and repair
Posted: Sun Apr 03, 2022 10:09 am
by catphish
js1tr3 wrote: Sun Apr 03, 2022 2:54 am I fried two legs.
I'm afraid I don't know how to disassemble the power stage, but I'm interested to know - how did you damage it?
Posted: Sun Apr 03, 2022 11:27 am
by js1tr3
Embarrassed, but by flashing the firmware of the openinverter with HV power applied. I was testing contractors and forgot that I left power on. That was an expensive mistake.
Posted: Sun Apr 03, 2022 11:52 am
by catphish
js1tr3 wrote: Sun Apr 03, 2022 11:27 am Embarrassed, but by flashing the firmware of the openinverter with HV power applied. I was testing contractors and forgot that I left power on. That was an expensive mistake.
Makes sense, thanks, definitely something to be careful of! By the way you've marked this thread as resolved (you ticked my reply), you should probably undo that since nobody has answered your question.
Posted: Sun Apr 03, 2022 1:03 pm
by js1tr3
Thanks,
Fat fingers on my phone.
This patent is instructive... but doesn't really tell me how to get things apart...
US10199804B2
https://patents.google.com/patent/US101 ... 10199804B2
Posted: Sun Apr 03, 2022 1:11 pm
by js1tr3
To remove the plastic cover and Goo I put 4 wood screws through the cover directly over the 4 torx heads and turned the screws to remove the plastic while liberally applying heat with a heatgun.
Posted: Sun Apr 03, 2022 1:23 pm
by EV_Builder
js1tr3 wrote: Sun Apr 03, 2022 1:11 pm To remove the plastic cover and Goo I put 4 wood screws through the cover directly over the 4 torx heads and turned the screws to remove the plastic while liberally applying heat with a heatgun.
Pictures would help massively...
Posted: Sun Apr 03, 2022 8:41 pm
by js1tr3
I'll stick a few pictures here.
http://warpedporsche.blogspot.com/2022/ ... n.html?m=1
Looks like it's still held by the power inlets, can't access the bolts and it looks like a purple ring locks the power pole in place, but I can't figure out how to release it. Otherwise the whole thing looks like it wants to come out.
Posted: Sun Apr 03, 2022 9:28 pm
by EV_Builder
Maybe not relevant but what is beneath the cap near the HV plugs?
It's well possible that you need to desolder the fets and then remove the board and then can see what you need todo next.
If the patent learns us one thing it is that welding and soldering is part of assembly process.
Posted: Sun Apr 03, 2022 11:40 pm
by js1tr3
Yup, checked that is a It's a breather gasket.
Not sure how u can hit all of them at once with an iron. Ordered a 1/4 drive swivel set to see if I can reach the bolt under the board that holds the power connector in place.
Posted: Mon Apr 04, 2022 5:31 am
by EV_Builder
1 for 1; You suck the tin away with a suction pen and after that clean it further up with solder wick would be my strategy.
Posted: Tue Apr 05, 2022 3:31 am
by js1tr3
Got it apart, once I figured out how the Rosenberger hpk connectors work. Pictures added on the blog.
I was right the little purple lock rings were key. Then simultaneously lifting the four fingers that hold the pins in place. I lifted each the slid a small zip tie into the slot to hold it unlocked.
https://www.rosenberger.com/product/hpk/
Posted: Tue Apr 05, 2022 9:35 am
by Peter
Well done and a big thank you for your efforts. I am sure your perseverance with the strip down will help others who may need to try to repair the power stage etc. Looking forward to seeing whats under the pcb.
Posted: Wed Apr 06, 2022 9:16 pm
by catphish
I've been doing some testing and I now believe this is an issue with the design of the openinverter SDU board. When the board is booting or programming, it doesn't output any PWM to the inverter, it just leaves these outputs floating. Ideally this should result in all the IGBTs being switched off, but instead, it results in all the IGBTs being simultaneously switched on, basically guaranteeing destruction if HV is applied!
Obviously, in normal operation this isn't a problem, but I have opened an issue on Github to suggest the addition of pull-down resistors. This would protect the inverter from destruction in a few cases, most notably if the STM32 is reset or programmed while HV is applied.
Posted: Wed Apr 06, 2022 10:51 pm
by EV_Builder
catphish wrote: Wed Apr 06, 2022 9:16 pm
I'm not sure if this is correct.
In the sense of the bootloader checks if there is a pin image in flash if it is it is applied.
Inverter firmware writes that image.
Also one could argue that in normal design the contactors are controlled by the board itself...
Saying all that, if adding pull-downs solves us issues we sure should do that in V8
Posted: Wed Apr 06, 2022 11:33 pm
by catphish
EV_Builder wrote: Wed Apr 06, 2022 10:51 pm In the sense of the bootloader checks if there is a pin image in flash if it is it is applied.
You're right, the openinverter bootloader does set these pins early in the boot cycle, and hopefully persists this during the rest of the boot, or during a firmware update, which should significantly mitigate the problem. Unfortunately, even if it never happens at any other time, resetting the chip will causes at least some period of time when the outputs are in an undefined state and *could* activate all the IGBTs. I would assume this is what happened to js1tr3. Despite the bootloader protection, I still believe it would be prudent to add hardware pull-downs to cover any period when (for any reason) the MCU isn't driving the pins. Doing it in the bootloader seems like more of a workaround in my opinion.
Posted: Thu Apr 07, 2022 9:59 am
catphish wrote: Wed Apr 06, 2022 11:33 pm You're right, the openinverter bootloader does set these pins early in the boot cycle, and hopefully persists this during the rest of the boot, or during a firmware update, which should significantly mitigate the problem. Unfortunately, even if it never happens at any other time, resetting the chip will causes at least some period of time when the outputs are in an undefined state and *could* activate all the IGBTs. I would assume this is what happened to js1tr3. Despite the bootloader protection, I still believe it would be prudent to add hardware pull-downs to cover any period when (for any reason) the MCU isn't driving the pins. Doing it in the bootloader seems like more of a workaround in my opinion.
The current firmware only instructs the boot loader to pull low precharge and dc switch pins. For the IGBT outputs it depends whether you're using active high or low configuration. In the latter case they need to be pulled high explicitly (maybe not pulled anywhere in active low case, as this mostly drives low impedance optos anyway).
It will only take a couple of µs until this mechanism acts. That is usually sufficient for the pins not to float high. I agree some week pull-down at least on the Tesla boards would improve the situation. The advantage of the software fix is that it also fixes older boards.
Posted: Fri Apr 08, 2022 1:07 am
by js1tr3
Thanks,
I've got the inverter power stage at work to use the BIG 325W iron. since my little 25w couldn't even melt the solder.
The goo in between boards renders the solder sucker pen almost useless, since it just tries to pull against a vaccum. Anyone know how to dissolve the (silicone?) potting compound?
I've got another DU (and HV fuse) on order from fleabay, and will swap the power stage and openinverter board. Fortunately, I can get the cover off without pulling the DU and battery.
reviewing the specs to add the pulldowns, can I tap into the six through board vias that connect to the MCU side of IC7 for the pulldowns?
would something on the order of 30-50k ohms work?
Posted: Fri Apr 08, 2022 1:08 am
by js1tr3
Any other precautions for using contactors (and pre-charge) controlled by the BMS rather than the openinverter?
Posted: Fri Apr 08, 2022 7:00 am
Maybe more like 10k, not sure how much is needed to make the floating voltage collapse. It varies between chips it seems.
In parallel I will add boot loader pull-down to the next firmware
Posted: Fri Apr 08, 2022 7:15 am
Just did it.
When changing pwmpol it takes 1 reboot to update the pin init structure. So when on an active low architecture, make sure to set this parameter and reboot while NOT connected to the power stage or at least with no high voltage.
Since pwmpol defaults to ActiveHigh you'll have the correct pin init commands written at first startup
UPDATE: apparently this firmware accelerates when asked to do regen, please do not use our check with extreme care
UPDATE2: this had to do with the hillhold feature, updated the attachment
Posted: Fri Apr 08, 2022 9:11 am
by catphish
js1tr3 wrote: Fri Apr 08, 2022 1:07 am reviewing the specs to add the pulldowns, can I tap into the six through board vias that connect to the MCU side of IC7 for the pulldowns?
I believe these 6 vias are the MCU side of the PWM buffer chip, so yes, you should be able to add the resistors there, but do double check. I would normally default to 10k for pull-downs, which should be low enough to prevent the floating, but high enough not to slow down the switching. Sorry for the slightly non-committal reply - I've not tested this myself so caution and testing is advised.
Posted: Fri Apr 08, 2022 9:13 am
by catphish
johu wrote: Fri Apr 08, 2022 7:15 am Just did it.
Thank you very much - this should definitely mitigate the problem with accidents during firmware upgrades. :)
Posted: Tue Apr 12, 2022 6:35 pm
by EV_Builder
What is the answer for the SDU? We need pull ups or pull downs?
And do we place them on the inputs of the 74HC or on those outputs...
Posted: Wed Apr 13, 2022 6:15 pm
by catphish
EV_Builder wrote: Tue Apr 12, 2022 6:35 pm What is the answer for the SDU? We need pull ups or pull downs?
They should be pull-downs (probably 10k) on the lines between the STM32 and the 74HC buffer.
