Good custom made driveshafts service.
Posted: Wed Apr 27, 2022 12:28 am
by EV_Builder
Wanted to give a big shout out to these guys in Poland!
Check out their website and ask them for a quote:
www.motomax.pl
Nice shafts, custom made from OEM splines.
Tesla to Porsche.
I delivered them the complete shaft (shut welded) and they made a new shaft and checked the parts and assembled it all.
Re: Good custom made driveshafts service.
Posted: Wed Apr 27, 2022 2:07 am
by TheSilverBuick
Nice!
Posted: Wed Apr 27, 2022 3:38 pm
by Tremelune
For US folk, I had a good experience here:
https://driveshaftshop.com/
Posted: Wed Apr 27, 2022 3:47 pm
by Gregski
cool, next time you're in a jam doing an EV Swap in Sacramento California, USA, Earth, Milky Way
Drive Line Services of Sacramento
704 Houston St, West Sacramento, CA 95691
dlssac.com
Posted: Wed Apr 27, 2022 4:57 pm
by TheSilverBuick
I've got a local driveline shop I plan on utilizing. Basically hand them a transmission flange and say 1310 rear yoke u-joint X inches (that's right!) long with a splined slip tube in it. May put a carrier bearing step in there if the transmission is not slid far enough back.
Posted: Wed Apr 27, 2022 5:43 pm
by Gregski
TheSilverBuick wrote: ↑Wed Apr 27, 2022 4:57 pm
if you plan on using the GS450h you have no choice but to run the center bearing support, these transmission output shafts are not designed to carry the driveshaft weight/load I don't think and you risk stressing and damaging the output shaft bearing, also if you don't have an independent rear suspension you have to use a two piece drive shaft to slide in and out of itself when the rear axle articulates up and down, again the GS450h transmission does not have a sliding output shaft like the American TH350
Posted: Wed Apr 27, 2022 8:39 pm
by TheSilverBuick
Good info! I knew the rear of the GS450h didn't slide, so that's the two piece is the splined slip tube I mentioned. I hadn't given any thought about the rear bearing design possibly not liking the slip tube load.
This tank definitely has a solid back axle.
Posted: Wed Apr 27, 2022 10:14 pm
by Gregski
TheSilverBuick wrote: ↑Wed Apr 27, 2022 8:39 pm
are those sui doors on that beauty, and what's her name?
Posted: Thu Apr 28, 2022 1:48 pm
by TheSilverBuick
Sure are. The finest of 1967 Ford Thunderbird technology! Has a very wore out drivetrain. Figured I could sink $12k into another grumbly V8 and transmission or try the electric route.
