Regen not working above 5mph
Posted: Thu Jul 28, 2022 10:40 pm
I have an SDU running openinverter revision ce8c1e55fb91cd928c4b5ad4ccc56940596640ee - parameters attached.
For some reason I cannot get regen to work except in a very small band at around 5mph. If I set offthrotregen to -30, it seems that potnom is set to -30 as expected when the throttle is released, but there simply isn't any noticeable regen at speeds above 5mph. If i allow the vehicle to slow down naturally, I feel absolutely no regen until the vehicle slows to 5mph, at which point I feel very sudden and very noticeable braking, which brings the vehicle to a near stop.
This suggests to me that regen is absolutely working, but something is inhibiting it at higher speeds. I can't find any obvious explanation in the source code, but I'm wondering if it could be a bug as this version with hill hold has not been released and widely tested yet.
Tomorrow I will repeat this test and obtain a detailed log of the DC current, speed, and potnom. If possible, I will also add fslipspnt and ampnom to my logging.
