Kokam cells, how do they perform? BMS
Posted: Thu Sep 22, 2022 10:00 pm
Hello all,
Would be interested to know how Kokam cells are performing. Reading the posts, I understand that some of you have used this brand.
I am planning to build my own pack using 103 Ah Kokam cells, 66 of them in series. The size of the cell is width:268, length (tabs excluded): 265, thickness: 12.8 mm
Comparing this configuration to OEM battery packs, it seems simpler; but why do OEMs use smaller capacity cells, building modules by connecting the cells in parallel and series? Is it because of space restrictions, as the modules (as opposed to a long string of large cells) can be arranged to fit under the car’s chassis? I don’t have an answer and would be interested to know your opinion on using large size cells VS modules built with smaller cells.
Other considerations:
1. How to build the enclosure having in mind the criteria: cells need to be compressed, prevent water ingress and condensation, liquid cooling / heating (it’s Canada!), prevent the box from flexing, as this could cause the cells’ walls to rub one against each other.
2. BMS. Selection of a system. I would be interested to try Johhanes' BMS, but probably is not yet ready for sale. In regards to SimBMS, I couldn’t figure out if it is suitable for 66 cells connected in series. Of course the choice is related to the skill level of putting the system together. If it requires some soldering, wire connection and installation of software, then it is alright. Here, I would appreciate your guidance as well. There is so much information on the forum, but I still couldn’t decide.
Your opinions would be greatly appreciated.
Cheers,
Paul
Cheers,
Paul
