Replace L110 GS450h oil pump
Posted: Sun Sep 25, 2022 9:01 pm
Let's figure out a replacement for the noisy, troublesome external oil pump on the GS450h L110 transmission. I'd like to use one, but not with this problem. Don't make Damien figure this out, he's got enough to do.
Here are the facts (which will be updated and collected here, to not have to search the thread)
* There's a second set of optional oil lines sealed with bolts instead of banjo fittings.
* The oil pump's mount has high and low pressure, which Damien said may be good for a 3D printed connector to a different pump, but asked that someone else do it. (been a while since I heard that, not sure which video)
But this inspired another solution:
*** Build an adapter (maybe just plate steel and a hose fitting) to use the current electric oil pump's mount for only the high pressure input from an external pump. Then run an inline OEM pump of similar specifications but not noise. Run a banjo adapter from the lower unused fitting to the pump to the new high pressure input where the old electric pump was.
Pressure required to properly function: ? (Damien said he had stock pump working at 30% duty cycle)
OEM pumps with necessary pressure: ?
OEM pumps that can be adapted to inline use: ?
OEM pumps so worth using, that an adapter should be designed for use here?
Would someone please design the adapter, that requires no modification to the transmission?
I think that defines the project. Anyone want to work on this?
Please provide corrections to my secretarial work.
