Enova 90kW motor and Damiens Combi V8 built inverter for sale
Posted: Sun Oct 02, 2022 1:40 pm
Hi Forum. I am looking to sell my Enova 90kW motor and fully built and working Damien (and Johannes) designed Combi V8 controlled inverter.
Power electronics are from the well known Enova Inverter with sturdy IGBT and large caps. I have run the setup in my car previous to buying an SDU and now the time has come to build another project EV so funds need to be gathered.
All documentation is provided and the test control panel means with a simple addition of 12v and a power supply of maybe 48v upwards and parameters adjusted accordingly the motor can be spinning in a few minutes. This is the same setup as Damien was using in his drift car and the torque is very good. I also have a Mitsubishi style gearbox (F5M431) out of a Proton 1.6 and the adaptor plate to marry the motor and gearbox together if you are planning such a conversion.
I can pallet the parts and forklift onto your transport.
Cost of the initial purchases was close to £2K, hoping for around £600 but sensible offers or swap for parts may be accepted
Please PM me if you are interested.
