Gen3 inverter connector (not unobtainable)
Posted: Fri Jan 06, 2023 7:39 am
by bexander
Regarding the Gen3 inverter connector that used to be unobtainable can in fact be bought.
https://openinverter.org/wiki/File:Priu ... _Body_.jpg
The housing can be bought from Toyota, cost was 89 SEK (~€8)!
Then terminals and wire seals are needed and after some web searching and testing I have concluded this BOM:
Connector housing:
Toyota G9260-47010, 36p
Toyota G9266-47010, 13p
Small terminal, 0.64:
0,22-0,35mm2
TE 1612290-1 (tested ok)
Sumitomo 8100-3455
Small wire seal:
Sumitomo 7165-1198
Small blind plug:
Sumitomo 7165-0797
Large terminal, 2.3:
0,3-0,5mm2
Yazaki 7116-4025 (tested ok)
Sumitomo 8100-0460
0,8-1,25mm2
Yazaki 7116-4026
Sumitomo 8100-0461
2,0mm2
Sumitomo 8100-0462
Large wire seal:
Sumitomo 7165-0342 D4,9mm d1,4-2,0mm
Sumitomo 7165-0343 D4,9mm d2,0-2,5mm
Sumitomo 7165-0344 D4,9mm d2,5-2,9mm
Large blind plug:
Sumitomo 7161-9787 D4,7mm
Terminal extraction tool
0.64 Terminals : Sumitomo 3070000 or 307-0000-03
2.3II Terminals : Precision screwdriver(1.2mm~1.6mm)
NOTE: The Sumitomo terminals are not tested but thay look the same as the ones I have tested and documents point to the Sumitomo extraction tool, hence my guess is they will fit as well.
Re: Gen3 inverter connector (not unobtainable)
Posted: Sat Sep 02, 2023 5:44 pm
by bexander
Updated first post with part nr for the small 13p connector housing that clicks into the larger 36p connector housing.
Posted: Mon Jul 15, 2024 2:26 pm
by LHelge
According to the wiki this connector also seems to fit the Nissan Leaf Gen2 inverter. I'm intending to use a Leaf power stack for an EV conversion and have bought all the parts but didn't find any signal wire harness. This is connector the last part I need to start building my own harness.
I would be very interested in which parts you ordered and from where, especially since you also seem to be located in Sweden.
Posted: Tue Jul 16, 2024 11:46 am
by bexander
Yes, will fit Leaf Gen2 80kW inverter.
Housings from Toyota.
Terminals from Mouser or AliExpress.
Seals from AliExpress.
Pinout for Leaf inverter connector
Posted: Wed Jul 17, 2024 9:14 pm
by LHelge
Great, thanks!
When you say you bought the housings from Toyota, do you mean from your local car dealership or is there some webshop where you can buy spareparts?
Posted: Thu Jul 18, 2024 4:25 pm
by bexander
I ordered them from my local car dealership, Toyota Center Mölndal.
Took 1-2 day for them to get the parts.
