MQB & MLB Can log Request - For Zombieverter Comm Additions
Posted: Sun Jan 08, 2023 6:32 pm
by Mitchy
Hey All.
Wondering if anyone has any sources for a MQB and MLB canlogs.
I have the DBC files already, but just looking for some examples to work with to write a Zombieverter CAN plugin for MQB and MLB models.
Lots of shared addresses between these two, as well as the Porsche 9x1/Macan. I've got the 9x1 codebase pretty much ported over as a start.
Overall there'll likely be a unified 2010 VAG selection, with switches to choose the MQB/MLB/9x1 implementations.
I don't intend the code to be elegant, but it'll be a good basis for refinement for the community to work on.
Re: MQB & MLB Can log Request - For Zombieverter Comm Additions
Posted: Sun Jan 15, 2023 9:58 pm
by RetroZero
Will be a while, but I'm waiting to see what Damien hacks up with his CAN data logger and getting one asap.
Posted: Mon May 06, 2024 5:21 am
by RetroZero
Got savvycan running with wifican @uhi22. Crocodile clip arrived. I'll see if it can be used for CAN logs. I tried it on a bench setup cluster and the data seems identical to the hardwire setup with wifican.
Edit - my crocodile clip is not yet operational. The data I'm seeing is from the hard wire setup.
Edit - 2, Got another Canadapter board on its way to connect independently to my bench setup and see what the crocodile says 🤞
Posted: Wed Jul 10, 2024 11:28 am
by RetroZero
Trying in another thread.... Capturing CAN data sent with VCDS and then playing it back (blinking LED on charger flap), I can't get the LED to blink. Are the magic bytes required when playing back CAN data? I tried it with the lock actuator too.....
Posted: Tue Feb 04, 2025 6:58 am
by Jacobsmess
Hi Mitchy, did you get any Canlogs from an MQB vehicle? thanks
Posted: Tue Feb 04, 2025 7:30 am
by uhi22
Is it clear which of the CAN busses is of most interest? AFAIR there are multiple, like engine CAN, body CAN.
And do we know where contact them?
Posted: Tue Feb 04, 2025 7:32 am
by Jacobsmess
uhi22 wrote: ↑Tue Feb 04, 2025 7:30 am Is it clear which of the CAN busses is of most interest?
For myself I suspect only the powertrain can is required but I have revived an old thread from 2023, not sure if Mitchy answered his question or not.
