Tesla LDU Open source board programming steps?
Posted: Thu Jan 12, 2023 6:50 am
Hi, I'm new to this. Decided to do Ev conversion from scratch using Tesla Large Drive Unit.
I been going through forum threads for quate a while now. Trying to educate my self.
So far I have Tesla LDU in my garage. I decided to go with Open Source Board by taking Gerber files and building it and programming my self. They had few things out of stock so I will need to finish soldering some resistors etc which is not a big deal.
Upon finalizing my order I came across few problems.
I can not find part numbers for all the PCB wire connectors or what seem called Latter, if any one can give me a hand with that it would help a lot. I believe it's these ones, check picture for attachments.
Also, I'm trying to understand programming procedure. Would like to know where to connect the ST link v2 on a board, I believe it's 3 holes on a board where it says prog next to connector 9. And how do you program? I see you need a bootloader, and firmware. I found firmware on gihub but not sure about bootloader.
Saw this topic on a forum about the bootloader but I'm confused whether this is for any stm32 processor... Any board sort to say including LDU control board.
viewtopic.php?t=1119
I'm pretty good at building and working on electronics, just need a few pointers. I would like to contribute to wiki page on programming topic because I noticed it's missing there at LDU page!!! After I figure all this out.
Thanks in advance.
Thanks in advance.
