Page 1 of 1
Wanted set of 6 BMW phev bms slaves
Posted: Mon Mar 13, 2023 8:04 pm
by Ev8
As above, looking for a set of 6 bmw phev bms slaves from the 9kwh 6 module battery, I have plenty from the 5 module pack but in order to add a 6th to my current 5s pack I need modules from the 6s pack so I don’t double up of can addresses
Re: Wanted set of 6 BMW phev bms slaves
Posted: Mon Mar 13, 2023 8:18 pm
by tom91
Are you looking for the Gen 1 slaves? You can renumber the Gen 1 can only slaves, renumbering code is in the SimpBMS code.
https://github.com/Tom-evnut/BMWPhevBMS ... hevBMS.ino
Posted: Mon Mar 13, 2023 9:31 pm
by Ev8
Thanks Tom I was aware that you could renumber them but didn’t realise they were identified by number and not unique id’s, and figured as I only had slaves from 5 module packs I’d end up with a duplicated Id, I’ll have to take a proper look at the code
Posted: Fri Oct 13, 2023 7:02 pm
by FFMan
or use a teensy and put then on separate can channels
