Help FOC tuning Prius gen 3 & Outlander PHEV rear needed
Posted: Thu Apr 06, 2023 10:04 am
I had my setup working ok on the bench but now it's in the car i can't it to work. On the bench i went through the FOC and video and arrived at what i thought was an initial but working set of parameters and wiring.
In transferring it to the car two things happened, there is like 5% chance the resolver wiring is wrong as my notes weren't as clear as they could have been. Also, during the winter whilst sorting out the mechanicals the V1C board got a bit corroded and furry, suspect it wasn't sealed. i clean that up carefully with contact cleaner, a razor blade and a brush and sealed it. It looks a little dull but ok i think. Everything else is the same as working on the bench i.e. using my test rig, not the throttle pedal in the car yet etc,. Using a test set of lIPOS about 120V
So where i am now.
With sine f/w motor turns ok
With foc f/w, i can plot the resolver return, it swings from 0-360 and jitter is around 1 degree, which all appears to be correct.
As there was doubt about resolver wiring and i went back and started the pair id process again, set syncofs to zero, but i find in any combination, with the bulb in series, as soon as i start the inverter the bulb lights, with manualid & iq set to zero. If i enter a value for manualid of say 3, the bulb gets brighter. The motor doesn't turn. The light tays on until i stop the inverter. I don't recall this behaviour before, what does this indicate ?
For comparison I have polepairs and respolepairs set to 5, and pinswap to 8.
I note the polepairs & respolepairs differs from a known good set of params for the phev front motor, but i guess they're different motors so could ?
any help much appreciated. Getting close but wheel turnage eludes me !
So where i am now.
