Page 1 of 1
Help: The motor shakes, but does not turn! There is a lot of current!
Posted: Tue May 09, 2023 1:46 am
by tt1012
If I have any more questions!
I will come to the forum for consultation!
Thank you all!
Re: Help: The motor shakes, but does not turn! There is a lot of current!
Posted: Tue May 09, 2023 9:58 am
by Mhs
I by no means an expert, however I suggest you to provide more details on your setup (motor and inverter details) to allow others to help you
Posted: Tue May 09, 2023 10:19 am
by Bigpie
Are you sure your motor phase wires are the correct order?
Posted: Tue May 09, 2023 2:13 pm
by tt1012
I have already solved this problem!
thank you!
But now I realize that my current sensor is not working! The voltage is normal!
1.6vă But there has been no change in the data of il1 and il2!
And after I refueled, he remained in idle mode!
I can't control any speed!
Posted: Tue May 09, 2023 4:00 pm
by tt1012
Bigpie wrote: âTue May 09, 2023 10:19 am
yes!
Posted: Tue Sep 12, 2023 10:18 am
by johu
Please don't delete your original question as then it's less helpful for others and also report back how you solved the problem
