Motor reversing with OI board - what's the best way?
Posted: Mon May 22, 2023 3:05 pm
by Zieg
Okay I hope I'm just overthinking this, but I'd appreciate some input. And maybe a brief discussion would be helpful to others.
I have a gen2 Leaf inverter with an Openinverter board, and I need to reverse the direction of the motor due to how it's mounted in the car.
My first thought was to simply wire my FNR switch backwards and call it a day. Is that a reasonable plan, or would I run into any issues with regen, peak power, etc?
I looked through the PINSWAP options in the wiki and thought maybe one of those would achieve the same thing, but wasn't totally sure. If that is a valid solution, does anyone know which setting to select? Is that better than wiring the FNR switch backwards?
And finally I do know I can swap two phases and two resolver wires, but since the inverter is mounted to the motor I'd rather not mess with the bus bars if I can avoid it.
Thanks!
Re: Motor reversing with OI board - what's the best way?
Posted: Mon May 22, 2023 5:22 pm
FNR backwards is one solution, setting "dirmode" to "SwitchReversed" is the same solution in software ;)
Certainly no need to mess with resolver or even phase wiring.
Posted: Mon May 22, 2023 6:07 pm
by Zieg
Ah perfect, thank you very much! Sorry I didn't see "SwitchReversed" as an option for Dirmode in the parameters.
