Gen4 Nissan Leaf stack CAN log for analysis
m.art.y
Has thanked: 38 times
Post by m.art.y »
I've tried running gen4 Nissan Leaf stack with a Zombie and it did not appear to run. PDM is now made by Toyota and has no labelling with charging power etc. It has identical round connectors and wires all seem to be the same. Dcdc converter did not start, there is also no bus voltage info in the CAN or it is encoded differently. I attach a CAN communication log between the Zombie and the Leaf stack for analysis. Do the CAN messages appear to be different?
leafgen4.csv
(95.43 KiB) Downloaded 641 times
CrAzY_DrIveR
Has thanked: 13 times
Been thanked: 8 times
Re: Gen4 Nissan Leaf stack CAN log for analysis
Post by CrAzY_DrIveR »
the toyota pdm looks a lot shorter than the older ones
Has thanked: 363 times
Been thanked: 249 times
Post by jrbe »
The Nissan leaf gen stuff is confusing. As far as cars I believe the current vehicles are Gen 2. For inverters we're on Gen 3 as far as I'm aware. Where is Gen 4 coming from?
m.art.y
Post by m.art.y »
jrbe wrote: Fri Sep 06, 2024 1:46 am The Nissan leaf gen stuff is confusing. As far as cars I believe the current vehicles are Gen 2. For inverters we're on Gen 3 as far as I'm aware. Where is Gen 4 coming from?
It might be wrong but the logic is simple: Leaf EM61 is gen1, Leaf EM57 80 kw is gen2, Leaf 110 &160 kw is gen3, and Leaf 2023 with Toyota PDM is gen4 as changes have been made and it does not work with Zombie out of the box.
Post by jrbe »
m.art.y wrote: Fri Sep 06, 2024 3:49 am ...and Leaf 2023 with Toyota PDM is gen4 as changes have been made and it does not work with Zombie out of the box.
That seems reasonable. Though if it's only a communications difference and the rest of the hardware is the same as a gen 3 (2018-?) it might make sense to call it 3.1 or maybe 3.5? If gen 4 hasn't been established by the community yet...
Edit, I just found the other post. These seem like gen 4 will be appropriate.
viewtopic.php?p=74585#p74585
Has thanked: 330 times
Been thanked: 847 times
m.art.y wrote: Sun Jun 18, 2023 5:50 pm do the CAN messages appear to be different
Yes one new ID and none of the content lines up.
Has thanked: 323 times
Been thanked: 352 times
Post by P.S.Mangelsdorf »
m.art.y wrote: Fri Sep 06, 2024 3:49 am It might be wrong but the logic is simple: Leaf EM61 is gen1, Leaf EM57 80 kw is gen2, Leaf 110 &160 kw is gen3, and Leaf 2023 with Toyota PDM is gen4 as changes have been made and it does not work with Zombie out of the box.
Question: I know the Zombieverter read-me says the Gen3 PDM is not supported. I remember reading somewhere that was because of issues with CHAdeMO. Can the Zombieverter run the Gen3 PDM (2018-2022) for just AC charging and DC-DC?
P.S.Mangelsdorf wrote: Thu Mar 20, 2025 6:47 pm Question: I know the Zombieverter read-me says the Gen3 PDM is not supported. I remember reading somewhere that was because of issues with CHAdeMO. Can the Zombieverter run the Gen3 PDM (2018-2022) for just AC charging and DC-DC?
Where does it say Gen3 PDM not supported? It should work, it had been confirmed by another forum user as it needed propper CAN waking and sleeping.
Some people been playing with the Wiki I see, corrected now.
tom91 wrote: Thu Mar 20, 2025 7:01 pm Where does it say Gen3 PDM not supported? It should work, it had been confirmed by another forum user as it needed propper CAN waking and sleeping.
Thanks Tom - it's still listed as Gen2 only on Damien's github.
Great to know it works - I'm working with a friend on a build plan for one of his cars and a full gen3 stack will probably be involved.
m.art.y
Post by m.art.y »
Hi, Leaf stacks from 2013 to 2023 all work with zombieverter. Stacks from 2017 to 2023 need to wire chademo differently as far as I know. AC charging work on all of them (not the 2023 onwards as CAN messages have been changed by Nissan).
m.art.y
Post by m.art.y »
tom91 wrote: Mon Nov 25, 2024 12:40 pm Yes one new ID and none of the content lines up.
Hi Tom, do you think it would be nice to add latest Leaf stack support into Zombieverter? As far as I know they are already supported by Resolve. What would be needed to implement this into Zombie? 😊
Are they different? I need a DBC file of the CAN messages and CAN logs and a test setup.
m.art.y
Post by m.art.y »
tom91 wrote: Sat Jan 17, 2026 1:42 pm Are they different?
I wired one of those later gen stacks (with Toyota PDM) and nothing worked while previous gen stack worked with the same setup. I took the log of comms between zombie and the stack but you probably need logs from an actual working car. Not sure where to get the dbc file though. I have all the components at hand so I could rig a test setup again.
