Help trying to get my LDU to spin for the first time
Posted: Sat Jul 22, 2023 1:27 am
by spiff
Hi Everyone,
I'm reaching out to get some troubleshooting tips on getting my LDU too spin on low voltage. Here's where I've gotten to:
- Openinverter board connected to LDU powers up fine and I can get to the home page.
- Using a 30V 10A bench power supply for HV testing and a freshly charged car battery for 12V supply
- Set UCDNOM to 0 and UDCSW at 20
- Precharge and main contactors connected and working properly (turning on and off at the right times)
- After the precharge and momentarily connecting the start pin, I'm showing 30V at the HV motor leads so I know it's getting power.
- Calibrated the throttle pedal and can map/see the values responding properly when I plot and try to push the pedal
- Tried removing the encoder and starting in manual mode starting at 5 for "fslipspnt" and increasing in increments of 5 up to 100
Motor does not spin for any of this.
Are there values I should be specifically looking at in the parameters to see if everything has been done properly or if something's not working? Any other suggestions?
Re: Help trying to get my LDU to spin for the first time
Posted: Sat Jul 22, 2023 5:48 am
by Bigpie
Make sure to watch this if you haven't, it could help avoid an expensive mistake.
Posted: Sat Jul 22, 2023 9:30 am
by catphish
spiff wrote: ↑Sat Jul 22, 2023 1:27 am
Is it drawing any current? It might simply be that it's not pulling enough power to get spinning.
Posted: Sat Jul 22, 2023 9:01 pm
by Peter
Hi spiff. If all your connections etc are ok as per Damiens video then you could try increasing Boost. When I first started I could not get my motor to run with a low voltage source, increasing Boost solved that but its only a suggestion ok. I guess you have direction fwd or rev enabled ?
Posted: Sat Jul 22, 2023 11:03 pm
by spiff
Thanks everyone for the responses. I did recheck/test everything as per the video. All initial meter readings on the inverter were fine.
The board is getting power and when I turn the axles manually and plot the speed it registers so I know the encoder wiring and connections are also good.
Again the contactor circuits (pre-charge and main) are working as I can hear them clicking on and off at the right times, and I do see 30V at the motor leads after "start" is pressed and the opmode is in "run". Direction is engaged (pin 7) showing forward.
Thank you for the tip on Boost. I will try that next. Hoping to update this thread with success!
Posted: Sun Jul 23, 2023 11:30 pm
by spiff
SUCCESS!!!!
After months of waiting for parts, replacing bearings and seals and then wiring everything up, the used motor that I bought 5 months ago that I had no idea whether is functional, actually spins!
Two things I ended up doing:
1. Needed to increase the boost value from default is 1700 to 10,000.
2. When I did that the axles started moving but very slowly and in a stuttering way. Even though I was using a stock tesla wire harness connecting the 23-pin port to the 4-pin encoder port, it looks like pins 2 and 3 needed to be swapped. Once I did that the axles responded smoothly to pedal inputs!
Thank you all. I'd like to contribute my own thoughts to the FAQ as there's a few things that I struggled with that may help others. Do I need special access? Where is the best spot... On here or github?
Posted: Mon Jul 24, 2023 10:35 am
Great to hear!
Maybe pinswapping of two PWM phases should be ported to async code, too. Should make encoder wire swapping redundant, right?
Posted: Sat Jul 29, 2023 4:27 pm
by asavage
spiff wrote: ↑Sun Jul 23, 2023 11:30 pm
