Can1 not working on Zombieverter
Posted: Mon Jul 31, 2023 4:00 pm
Returning from an MOT test to actually have a fully functioning and road legal BMW Z4 with zombieverter and GS450h transmission and the car started playing up.
Long story short the 12v battery voltage was so low that everything went haywire.
Before discovering this and as it was pouring with rain I took the vcu out and tried to down load to an earlier software version on my test bench and happily I connected 12 volts to pin 28 and ground to pin27, yep what an idiot.
Anyway this resulted in a loss of Can 1 that the IVT shunt was connected to thus giving a precharge fault as no HV was showing. I have tried replacing IC16 transceiver which is connected to pins 27 and 28 but no luck there, the 120 ohm resistor is ok and I believe the connections from IC16 go straight to the STM32 so not much else to check with my skill set.
Connecting the IVT shunt to canbus 2 with the vehicle canbus, which interfears with the IVT shunt, programmed to can1 gives a full set of hv readings. Run is showing in the software and the oil pump is happily humming away. There is an output from my inverter relay as well. Selecting drive or reverse also shows as selected in the software but the car does not move.
Questions are,
Must the IVT shunt be connected to Can 1 for the car to run or will Can2 do (assuming you move the can wiring to the relevant Can terminals on the VCU) i.e. does the shunt need to put its can input into the STM32 through Can input 1. So would this cause the car not to move?
Is there anyone who can check and repair the vcu I am happy to pay for a repair if that is what is needed? I am based in the Andover area.
Questions are,
