Jumpy start, but smooth accel on SDU in VW T2
Posted: Thu Sep 07, 2023 2:16 pm
by Kitlacey
Hi all,
We have an SDU in a VW T2. We've used several of these with success using Zero EV's inverter settings. We're now using an Open inverter board so I'm copying a lot of settings from my previous Zero EV boards to this one. Everything is working great except setting off from 0RPM. At present, I slowly press the throttle until it reaches 30% travel (my regen limit) and then the SDU jumps us forwards into motion. Once it's moving, it drives great, but setting off is scary and a little uncomfortable. The inverter temp doesn't love me for it, and slow manoeuvers in reverse are nearly impossible.
Any suggestion what figures to adjust? I can supply full parameters if necessary, I just wondered if someone knows the magic bullet!
Kit
Re: Jumpy start, but smooth accel on SDU in VW T2
Posted: Thu Sep 07, 2023 6:33 pm
AAP - Always attach parameters
Sounds like ampmin too high
Posted: Thu Sep 07, 2023 9:54 pm
by catphish
Almost definitely ampmin or boost are too high. Post parameters and we can comment more accurately.
Posted: Fri Sep 08, 2023 8:40 am
by Kitlacey
here you go!
johu wrote: ↑Thu Sep 07, 2023 6:33 pm
Posted: Fri Sep 08, 2023 12:50 pm
by Kitlacey
AMPMIN was 5 so I lowered it to 4
BOOST was 2900 so I oput that back to the 2200 default.
The Jump is a little better after that, but the acceleration now feels very sluggish
Posted: Sun Sep 10, 2023 6:51 pm
At least for me the parameters don't look suspicious. Anyone?
Is your throttle signal all nice and linear?
Posted: Mon Sep 11, 2023 7:56 am
by Kitlacey
Yes, it's a new 0-5v variable pedal so it's all very smooth
johu wrote: ↑Sun Sep 10, 2023 6:51 pm
Posted: Thu Sep 14, 2023 8:07 pm
by catphish
For what it's worth, I believe everyone suffers with "jumpy" start on the SDU. It's one of the primary reasons I created my fork, and I believe a major reason why ZeroEV stopped using this drive unit. I spend weeks tuning the SDU so you might want to try these parameters to see how it compares:
boost: 3200
fweak: 230
ampmin: 0
fslipmin: 1.50
It's also worth noting that the throttle dead zone makes this "feel" worse, because your foot isn't used to finding the zero point. I don't use regen so my throttle doesn't have the 30% deadzone, and I found that made the experience quite a bit better.
Posted: Thu Sep 14, 2023 8:22 pm
by uhi22
Is it possible to create a plot which shows the throttle and the torque for some seconds while the "jumpy start"?
Posted: Fri Sep 15, 2023 8:30 am
by muehlpower
catphish wrote: ↑Thu Sep 14, 2023 8:07 pm
uhi22, tom91, I and others have discussed the "dead zone" problem here.
viewtopic.php?p=60101#p60101
Maybe it's time to implement something like this in the firmware.
Posted: Sun Jun 09, 2024 3:29 am
by alexbeatle
Could you please share your successful parameters? Tuning an SDU on my T2 as well.
