How does AC (smart) charging actually work? PWM explained!
Posted: Wed Oct 04, 2023 2:32 pm
by Gregski
very detailed explanation if you want to test your inner Geek
Re: How does AC (smart) charging actually work? PWM explained!
Posted: Thu Oct 05, 2023 10:01 am
by Gregski
Video Takeaways With Direct Links Back To The Video
Two Different Types of Charging Plugs
Posted: Thu Oct 05, 2023 10:19 am
by Gregski
The EVSE Can Show One Of Six Different States / or Statuseses
EVSE Status: A, B, C, D, E, F
Posted: Thu Oct 05, 2023 10:25 am
by Gregski
Posted: Thu Oct 05, 2023 10:31 am
by Gregski
Posted: Thu Oct 05, 2023 10:36 am
by Gregski
Status C/D
C = Charging
D = in the old days of lead acid batteries meant Charging with Ventilation
Posted: Thu Oct 05, 2023 2:08 pm
https://en.wikipedia.org/wiki/SAE_J1772 This has all the bits you are covering listed per topic.
Posted: Mon Oct 09, 2023 6:43 am
by xvyDFatih
How can we detect that an ac or dc charger is plugged?
Gregski wrote: Wed Oct 04, 2023 2:32 pm very detailed explanation if you want to test your inner Geek
Posted: Mon Oct 09, 2023 4:53 pm
DC chargers go into 5% duty cycle, thus requesting digital communications instead of PWM.
Posted: Tue Oct 10, 2023 3:34 pm
by uhi22
Yes, and AC chargers have two possibilities: Either use a higher PWM ratio, which defines the allowed current, or apply 5% and announce in the high level communication (IP, TCP, V2GTP, EXI) during the negotiation of the charge parameters that they support AC.
