Best use for Tesla 3 modules with damaged cells?
Posted: Wed Oct 25, 2023 1:51 pm
First post so be gentle.
As noted by TrueSoln, here in NZ we (now) get our Tesla 3's from China and the standard range ones come with CATL LFP cells.
These are the usual 2 short/ 2 long modules but possibly easier to electrically split the cells apart than the US ones.
Difficult to physically re-configure to shorter lengths due to the single cooling tube on the bottom.
So I'm thinking that even thought the cells are pretty much brand new (2022) and there is a damaged cell at the front of module 1 and 2 due to the accident, the best use for these modules would be to leave them as they are physically, and reconfigure them to 48V modules by cutting the alloy busbar between certain cells and wiring up generic external 48V BMS modules.
Note: The above image shows a close-up of one terminal of the cell with the flexible BMS circuit board laying on top and an exposed portion of the inter-cell busbar with the oval laser weld that connects the underlying LFP cell with the busbar. Just above is another exposed part of the aluminium busbar that narrows in size, presumably as a fusible link. The plan is to dremel through that link to seperate the cells then SOMEHOW connect cables there to use as new connection points? Tig welded alloy cable?
They would then be mounted vertically in a container so that a passive cooling system could be set up using the standard Tesla cooling tubes (with external radiator on the shaded side of the container and used as a large 48V solar storage battery.
The slightly damaged cells still show a voltage, but any current demand would likely cause a fire so I would leave them in place, but disconnected. Left in place because I supect these cells might be glued down to the aluminium cooling plate and to the adjacent cells.
Although I need cells for ev conversions I think I'm better off using batteries from other vehicles for this as they are so much easier to physically reconfigure due to cells being completely seperate with their own cooling plumbing? I'm talking about Kia/Hyundai/Leaf here.
