Mitsubishi CAN communication
Posted: Tue Oct 31, 2023 5:24 pm
I decided to make a set of reports from Mitsubishi components when operating. I think we can use those reports to control several things in a car while driving.
Mitsubishi Inverter
0x289 8bytes at 100ms
B0+B1 = torque report = ((H*256+L)-10000)/10
B2+B3 = RPM report = ((H*256+L)-20000)
B4+B5 = HV report = ((H*256+L))
B7 = RSDN pin status = 04 - not connected, 00 - connected
0x299 8bytes at 100ms
B0 = Peak motor temp B-40 [°C]
B1 = motor temp B-40 [°C]
B4 = motor temp B-40 [°C]
0x732 8bytes at 100ms
B0+B1 = motor current 1 report Ia= ((H*256+L)-1000)
B2+B3 = motor current 2 report Ib= ((H*256+L)-1000)
B4 = rotor angle report
Calculate motor current 3 report Ic
Ic = -Ia - Ib
In this equation, Ic is the current in the third phase, and Ia and Ib are the current values in the first and second phases, respectively. Assuming that the system is balanced.
Calculate the DC current
DC Current (Idc) = |Ia| + |Ib| + |Ic|
Mitsubishi charger/DCDC
0x377 8bytes DC-DC converter status
B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit)
B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit)
B4 = Temperature 1 (starts at -40degC, +1degC/bit)
B5 = Temperature 2 (starts at -40degC, +1degC/bit)
B6 = Temperature 3 (starts at -40degC, +1degC/bit)
B7 = Statusbyte (h20=standby, h21=error, h22=in operation)
bit0(LSB) = Error
` bit1 = In Operation
bit3 =
bit4 =
bit5 = Ready
bit6 =
bit7(MSB) =
0x389 8bytes Charger status
B0 = HV-Batteryvoltage (hAB=342V -> 2V/bit)
B1 = AC-Mains voltage (hE2=226V -> 1V/bit)
B2 = DC-charge current (1?) (h5B=9,1A -> 0,1A/bit
B3 = Temperature 1 (starts at -40degC, +1degC/bit)
B4 = Temperature 2 (starts at -40degC, +1degC/bit)
B5 = Statusbyte (CA while charging) bit0(LSB) =
` bit1 = Mains voltage present
bit2 =
bit3 = Charging
bit4 = Error (no CAN messages received)
bit5 =
bit6 = DC-DC converter request active
bit7(MSB) = 1KHz pilot present
B6 = AC-Mains current (h91=14,5A -> 0,1A/bit)
B7 = DC-charge current (2?) (same as B3, sometimes differs by 0,1A)
0x38a 8bytes Charger status
B0 = Temperature Raises together with other temperatures, but with +5deg offset
B1 = Temperature (starts at -40degC, +1degC/bit)
B2 = DC-bus voltage (9B=310V -> 2V/bit)
B3 = PWM-signal from EVSE (h19=25% -> 1%/bit)
B4 = Status
bit0(LSB) =
` bit1 =
bit2 = Wait for mains voltage
bit3 = Ready for charging
bit4 =
bit5 =
bit6 =
bit7(MSB) =
B5 = 00
B6 = 00
B7 = 00
Mitsubishi Heater
0x398 8bytes at 100ms
B0 = 00->01 as soon as 0x285h is received
B1 = seems to be current report [Current = dec value/10]
B2 = could be power applied. It certainly changes fast enough with current.
B3 = seems to be inlet temperature [temp=dec value-40]
B4 = seems to be outlet temperature [temp=dec value-40]
B7 = h70 when HV is <175Vdc, h00 when HV >175Vdc. So 175V seems to be the low-voltage limit
Mitsubishi AC compressor
0x388 8Bytes at 100ms
B0 = status, 7C start, 02 no power, 01 power present.
B2 = RPM report high byte
B3 = RPM report low byte
b4 = seems to be amp flow [current=dec value/10]
B7 = CAN status 00-No CAN, 01-CAN error, 02-heartbeat 0x285 present.
Mitsubishi Inverter
Ic = -Ia - Ib
bit0(LSB) = Error
bit3 =
bit4 =
bit5 = Ready
bit6 =
bit7(MSB) =
bit2 =
bit3 = Charging
bit5 =
B4 = Status
bit0(LSB) =
` bit1 =
bit4 =
bit5 =
bit6 =
bit7(MSB) =
B5 = 00
B6 = 00
B7 = 00
Mitsubishi Heater
