SDU brake lights output!?
Posted: Mon Dec 18, 2023 1:03 pm
Hello folks.
Quick question.
How do you trigger the brake lights from the SDU OI board (I have v6) in your projects?
I have a pressure switch on the brakes proportional valve, which I will use to trigger the max. regen - brk sw input to the OI bored. Planning to use the same signal to trigger the lights during pedal braking. But what about during regen braking, when the vehicle slows down from regen?
Thanks in advance.
Quick question.
Thanks in advance.
