Axle Adapters
Posted: Sun Dec 24, 2023 4:46 pm
Hey everyone, currently working on the issue of getting power from the motor to the wheels. I'm currently weighing the options of:
1. Lathing down the Tesla input stub, machining an adapter plate, and welding the two together. The issue with this is I'm not sure what alloy the Tesla stubs are made of, and what heat treating it has undergone. I would take this part to a professional welder who would have more knowledge on how to approach this than me, but I don't even know what alloy to machine the adapter plate out of. This would be very similar to what Jon Volk did as pictured. The benefit is I would be able to use stock axels.
2. Machining an entire adapter plate from scratch. It looks like the Tesla stubs are 29 spline, 31.5mm OD 29mm ID 30 degree pressure angle. This would probably be measurably more expensive, and I'm worried about the splines fitting correctly after machining.
3. Custom axles. In this case I would get axels made that are thicker, and get the Tesla "tripod" CV on the inside of the half shafts.
What do you guys think the best route is (while hopefully keeping it cheap)?
