Page 1 of 1
Zombieverter with DHAB LEM current sensors
Posted: Mon Dec 25, 2023 10:53 pm
by Jacobsmess
Hi, I've got a couple of LEM current sensors that came with a pre charge setup and was wondering if anyone has managed to implement them with a zombieverter?
Re: Zombieverter with DHAB LEM current sensors
Posted: Tue Dec 26, 2023 3:54 am
by Zieg
Hm, I'd also like to know this. I think it would be necessary to change the precharge routine to poll the inverter for a voltage reading?
Posted: Tue Dec 26, 2023 11:33 am
by tom91
The Zombie will not work with an analogue current sensor without a lot of effort and testing. The ISA Shunt does a lot of calculations none happen within the Zombie.
So the ISA shunt contributes the the following functions with in the Zombie:
-SOC calculations based on the consumed Ah reported from the ISA Shunt
-IDC measurement
-UDC measurement for precharge
So there needs to be a lot of code work and testing to be done to get these features working.
-IDC needs coding to read analogue inputs do a bunch of filtering and averaging
-SOC then needs to be based on the IDC reading over time
-UDC measurement for precharge, this will need to then as suggest come from an inverter used
