Calibrated RPM from PWM output on Zombieverter VCU for speed
Posted: Wed May 08, 2024 9:31 am
I am installing a Leaf drive unit to a Peugeot 106 Electrique.
The speedo used to be powered by a sensor sensing the teeth on a gear on the original drive motor.
Does the Zombieverter have a configurable RPM output using the PWM or alternatively an analogue output where I could drive an analogue to frequency converter.
