Motor to gearbox couplers
Posted: Thu May 23, 2024 4:19 pm
My E46 conversion has just knocked out the second version of the coupler.
For context, i removed the 2l diesel lump from the bmw and fabricated an adapter plate for an Outlander motor so the shafts had a 1cm gap between the tips. Line up felt good, with 1mm or so in 1 plane, spot on the other.
The first coupler was solid, splines from motor and clutch centre welded solidly together. That lasted maybe 2000 miles but eventually knocked the splines off the motor and gave up, In fact splines both end had taken some wear.
Second iteration (new motor) had a rubber doughnut/rotoflex coupler between the shafts. This has just knocked all the splines off the clutch centre that was on the gearbox shaft. Other splines all look ok.
I am wondering what the issue is and what next and wondered what others had done ?
I wonder is some of the issue related to the the fact the gearbox input shaft would have been supported at its tip by a spigot bearing in the flywheel when mated to the engine, and now has no such support. Maybe at speed, imbalance cause wear ?
Any tips and advice much appreciated.
