Loresamp
Posted: Sat Feb 01, 2020 10:07 am
by Oskar
I'm trying to get my gen 2 motor to show a sign of life with no luck. The only error I get now is the loresamp. Wiring seems to be ok but I need some guidance to continue troubleshooting. I need to know which pins and what to measure and also if there is some parameters to check.
4.65.R-sine
Rev 3 board
24V
Re: Loresamp
Posted: Sat Feb 01, 2020 10:38 am
You should use the recent FOC firmware: https://github.com/jsphuebner/stm32-sin ... ses/latest (stm32_foc.bin)
LOWRESAMP means the resolver signal amplitude is too low.
Please check the resistors:
R40=510 Ohm
R41=10k
R42=R44 = 3k3
Re: Loresamp
Posted: Sat Feb 01, 2020 3:06 pm
by Oskar
R40 = 4k7
R41 = 4k7
R42 = 3k3
R43 = 10k
R44 = 1k2
Well 1 out of 5 is correct ๐Ÿค”
Re: Loresamp
Posted: Sat Feb 01, 2020 3:48 pm
Ok, R40 and R41 is just added. So 4k7+4k7 is close to 10k+0.5k. R43 has nothing to to with excitation. R44 should indeed be 3k3.
Did you run the latest software and parameters from wiki?
https://openinverter.org/wiki/Configura ... Leaf_Motor
Re: Loresamp
Posted: Sat Feb 01, 2020 6:55 pm
by Oskar
I checked again to be sure and the R44 is 1k2. Do I need to replace this then?
Now I'm running latest software (FOC) and parameters but as soon as I start the inverter I get the WARN - LORESAMP error. If I start without connecting the resolver there's no errors and of course nothing happens when I engage the throttle. Like I said I've only connected 24V now for testing but it should work anyway right?
Re: Loresamp
Posted: Sat Feb 01, 2020 11:04 pm
Yes replace it. 24V is ok for testing and certainly won't cause that error
Re: Loresamp
Posted: Sat Feb 29, 2020 5:25 pm
by Oskar
Resistor is replaced but I still get loresamp. But now at least the motor is trying to spin.
Seems I can't upload leaf parameters to 4.76 FOC firmware for some reason.
Re: Loresamp
Posted: Sat Feb 29, 2020 7:30 pm
by damian.lo
If You are trying to load parameters from wiki configuration files look at last parameter if looks in Your file like:
"tripmode": 0,
It should be without last comma.
Re: Loresamp
Posted: Sun Mar 01, 2020 9:53 am
by Oskar
Thanks Damian. Fresh parameters and software now loaded but unfortunately error still remains.
When engaging the throttle motor makes sounds and tries to spin, but it's like it doesn't know which direction to spin at. I've tried both fwd and rev.
Re: Loresamp
Posted: Sun Mar 01, 2020 1:37 pm
Are you getting valid angle feedback, i.e. angle running from 0-360 as you spin the shaft by hand? Will have to set the plot to 1000 samples
Re: Loresamp
Posted: Wed Mar 04, 2020 12:15 pm
by Oskar
No feedback from resolver :( I've checked wiring again and it's all good. I also checked resistance from resolver to main connector and everything was in range according to a document I got from Langoo. Any suggestions what to check next?
RES_R1 - GND = 13 ohm
RES_S2 - RES_S4S1 = 29 ohm
RES_S4S1 - RES_S3 = 29 ohm
These are the results measuring from pins on the mainboard.
Re: Loresamp
Posted: Fri Mar 20, 2020 3:35 pm
by Oskar
Voltage between R1 or GND and S4S1, S2, S4 is 1.5V
Re: Loresamp
Posted: Fri Mar 20, 2020 4:46 pm
Oskar wrote: โ†‘Sun Mar 01, 2020 9:53 am Thanks Damian. Fresh parameters and software now loaded but unfortunately error still remains.
I have the same effect when i try to start my motor. It tries to spin in one way, but decides it is not correct and goes to the other side. It happens in like 25ยฐof an arc give or take.
I have good resolver reporting from 0 to 360. Tested with wifi dial.
I noticed resolver position jumps by a +/-2ยฐ.
My resolver S2 and S3 signal has more than 5V peak to peak, but i can stil get good reporting from the dial.
I measured and i get:
R1-R2 = 54R
S1-S3 = 45R
S2-S4 = 45R
It does seem that exciter winding has more turns than Sin/Cos.
I think resolver has some signal boost on sin/cos.
EDIT
Hm... i added 10K pulldown resistors to S2 and S3 lines to step down voltage from sensor and it is no better.
I tried to follow the procedure on wiki and when i went higher than 30A in "manualid" i also got "LORESAMP" warning.
Inverer was still pumping current into motor but error led was lit.
Re: Loresamp
Posted: Wed Apr 08, 2020 7:05 am
Just checked the resolver code:
   int sin = adc_read_injected(ADC1, sinChan);
   int cos = adc_read_injected(ADC1, cosChan);
   minSin = MIN(sin, minSin);
   maxSin = MAX(sin, maxSin);
   //Wait for signal to reach usable amplitude
   if ((maxSin - minSin) > MIN_RES_AMP)
      if (invert)
         return SineCore::Atan2(-sin, -cos);
      return SineCore::Atan2(sin, cos);
   else
      if (0 == startupDelay)
         ErrorMessage::Post(ERR_LORESAMP);
      return 0;
So it records the minimum and maximum amplitude of the the sin signal. But if the motor is stationary (which it usually is after startup) and happens to be in a position where the sin-amplitude is low, it will assert the LORESAMP warning for no reason. Gotta work on that...
Re: Loresamp
Posted: Wed Apr 08, 2020 11:37 am
by jerrykco
johu wrote: โ†‘Wed Apr 08, 2020 7:05 am Just checked the resolver code:
Tonight I will start the inverter rotating the motor shaft for different positions when the Inverter is powered on to take readings of sin-amplitude measurement noting min and max amplitude of sin.
Re: Loresamp
Posted: Wed Apr 08, 2020 11:22 pm
by jerrykco
Here are the plots for sin. I rotated the the rotor and tonight when O powered up the inverter, and manually started the inverter via WiFi, I got no errors.
So connected the scope and watched as I rotated the rotor. I captured the high and low.
BTW, because of the Magnets, the rotor has positions it comes to rest at. of those positions, one has a sin voltage of almost nil.
HIGH - 3.325V
LOW - 201.5mV
COS HiGH (Didn't do low. But watched it as I suun the rotor. Goes close to nil like the Sine.
Re: Loresamp
Posted: Fri May 01, 2020 11:14 am
by Oskar
I need to get my hands on a scope to check if my resolver is bad.
Motor is spinning and shaking almost like a original VW air-cooled engine that runs on 2-3 cylinders. Maybe I should be happy with it as the way it is and call it "vintage feeling" ;)
https://gofile.io/?c=uB7tSy
Re: Loresamp
Posted: Fri May 01, 2020 12:01 pm
by jerrykco
Oskar wrote: โ†‘Fri May 01, 2020 11:14 am I need to get my hands on a scope to check if my resolver is bad.
Watched your movie, mine is currently on the bench too and when I finally got all the connections right and followed the instructions and hints, I was able to spin it up. Started slow but then it rocked once when the motor torqued up and it went to 10,000 RPM on the bench as I scrambled to cut power.... Scared the crap out of me.
Because I had the Inverter laying on the bench, upside down and sideways, I had to label the 3 phase connections between the Inverter and the Motor.
I also triple checked the Resolver connections. And had to by some shielded twisted pair wires for those connections.
Re: Loresamp
Posted: Sun May 03, 2020 4:51 pm
by Oskar
jerrykco wrote: โ†‘Fri May 01, 2020 12:01 pm
Wow! It's funny how one can be prepared that things could get out of control, but when it happens brain goes instantly offline for a moment. In case motor would rush for some reason while driving I really hope brain doesn't freeze for too long to push in that emergency button.
I have everything connected 1:1 as original so phase and resolver connections should be right. Also the resistance seems to be in specs. I still have a lot to learn so it might take a while to finish up my project.
Re: Loresamp
Posted: Sun May 03, 2020 10:26 pm
by jerrykco
Oskar wrote: โ†‘Sun May 03, 2020 4:51 pm
Oskar, I was not using the throttle. I was doing this in Manual mode using manualid to 1 and then set manualiq to 3. No spin. Then manualiq to 10 and away it went. There is another thread you should read through if you haven't seen it yet.
See viewtopic.php?f=3&t=683
Re: Loresamp
Posted: Wed May 06, 2020 10:53 am
by DarkwingDuck
Hello Oskar!
Are you based in the Stockholm area? In that case I could probably swing by and have a look. Maybe we could collaborate? I have my Leaf motor turning since yesterday (but with errors, probably from parameter settings/using only 60v test pack voltage)
/David
Re: Loresamp
Posted: Wed May 06, 2020 11:56 am
by jerrykco
Oskar and David,
Have you seen this post from Johannes?
"If you're having start problems, please read here"
viewtopic.php?f=10&t=738&p=10465#p10405
I am about to try to integrate the Prius Throttle, and will be trying this new version.
Re: Loresamp
Posted: Wed May 06, 2020 11:25 pm
by DarkwingDuck
I just got it all working, default motor settings were WAY off. I thought the Leaf board came with nissan motor settings pre-flashed. Assumption is the mother of all fuck-ups. Changed to Leaf settings from wiki and its revs silky smooth without errors
Thanks for the heads up, will install update!
Re: Loresamp
Posted: Thu May 07, 2020 4:07 pm
by Oskar
DarkwingDuck wrote: โ†‘Wed May 06, 2020 11:25 pm I just got it all working, default motor settings were WAY off. I thought the Leaf board came with nissan motor settings pre-flashed. Assumption is the mother of all fuck-ups. Changed to Leaf settings from wiki and its revs silky smooth without errors
I finally got it running. Yesterday my new scope arrived and when I was playing around setting it up and connecting the resolver it suddenly came alive. Even though I triple checked all connections before it must have been a bad one somewhere.
https://gofile.io/d/yBmlIB
