Planetary mod to split MG1 and MG2 for dual power output
Posted: Wed May 29, 2024 7:00 am
In the Toyota hybrid trans, MG1 and MG2 are permanently connected via a planetary gearset mounted in between them.
If you have an app where you want to use MG1 and MG2 for different tasks (eg MG2 for driving wheels and MG1 for a PTO output on a tractor) you have to decouple them.
In an ideal world, simply removing the planetary gears would de-couple them, but doing this also decouples MG1 from the ICE input/output shaft because MG1 is connected to the planetary gear assembly via a splined tube.
So once you remove the gears, you have to join the ICE shaft with MG1's driveshaft.
Here are some photos from my nearly successful 1st attempt at gearshaft modifying.
Here you see the end of the planetary gear set. In the very centre is the ICE shaft with a splined hole that drives an internal oil pump. There a 4 welds around the outside that hold the gearcradle in place and you an see the small shafts for the planetary gears are held in place by squishing out a tubular bit (not sure what the technical term for this is).
Now the welds have been taken out with a cutting wheel on a angle grinder and the shafts are partially drilled out.
Once that is done the carrier and gears are discarded.
Placing MG1's driveshaft tube back on the ICE shaft, you can see that the two do not have a common bearing surface so the tube has a lot of slop in it. This is not good. Note that the centre gear of the planetary gearset (seen at the back) is no longer used and just sits there minding it's own business.
So these two items need to be permanently joined but maintaining concentricity.
Firstly I decided to practice me little-used lathe skills to get rid of the extra bits of flange.
This leaves us with a fairly neat unit ready to join the inner and outshafts together. Now the tricky bit - ensuring the shafts are concentric.
(continued in next post)
