GS450h Transmission and Inverter. Loss of drive since low 12volt battery voltage whilst driving.
Posted: Thu May 30, 2024 4:56 pm
Last July I finally managed to get an MOT on my conversion (BMW Z4). Happy days you would think. On the journey home the car started to jerk badly and lose drive on and off. This was due, I thought, to a low 12volt battery. It was enough to make me give up my project until recently and yes the car is listed in the classifieds for sale.
Whilst waiting, hopefully, for some interest in the car I started to look at the car to move things along if no one is interested in a purchase. Now the reason for the post.
I have fitted a new zombiverter and used the 2.0a firmware, this was the latest version before the MOT. I also replaced a blown pre-charge resistor. I assume that the pre-charge stays energised even when the VCU is in the run mode and for some reason it was trying to drive the car.
Unfortunately I only have a small amount of jerky movement forward with something like 30% throttle applied. Reverse gear gives no movement but a bit of a high pitched but not too noisy whine/whistle even at full throttle. I have increased the oil pump from 30% to 50% duty cycle in case the oil pressure in the gearbox was a bit low.
Checking the spot values there are no faults showing and all indications are that the inverter is talking to the the VCU. I have removed and stripped out the inverter as far as possible to see, or smell, if anything is blown but there is nothing obvious.
Any suggestions on how to proceed would be gratefully received.
