Gs450h inverter: can zombieverter VCU control boost converter
Posted: Wed Jun 12, 2024 5:46 am
Hi, Im Thomas! Im studying electrical engineering as an undergrad and have been interested in the realm of diy electric mobility and energy for while. New to the forums but have been reading along, which has been getting me slowly poised up for a EV conversion. EXCITED.
Finally pulled the trigger and acquired a Gs450h inverter and tranny for the conversion i want to do. Wanting to go down route of using zombieverter VCU to control.
So I'm committed now. Started to think in more detail about options for batteries and i have this one crazy (well its crazy in my mind) idea that would make use of the boost converter in its OEM use case.
Would appreciate someone with more experience than myself pointing out the fatal flaw i have yet to see in this:
Motivation: I want a cheap-ish and powerful build. ~200kW and range isnt a huge deal maybe up to 150km or so. For the big players this prolly isnt overly impressive but for a newb like me... THATS COOL ENOUGH.
Prospected conversion vehicle is GT86 which doesnt have much space for heaps of batteries either. Originally leaning towards LFP cells for good balance but realised even if i was using power LFP cells. id need HEAPS to comfortably to 200kW at like 5C and have reasonable range. Noticing that battery hookup also lists LTO cells which turn out to comparable energy density to LFP yet WAYYYY more power. To complement its low energy density perhaps NMC can be used which would be more space efficient in my space restricted application.
The idea would then be:
1. Since the GS450h has a built-in boost converter it should be possible to essentially do a semi-active hybrid battery configuration
2. LTO is connected directly to the inverter (ie the usual Gs450h conversion topology where the DC/DC is bypassed), then the NMC pack is connected to the boost converter input.
3. Ignoring possible dodgy startup conditions, nominally the system would act just like the typical Gs450h conversion where the main pack on the inverter bus provides majority of power
4. However im using LTO so there isnt much energy in that pack. So the NMC pack is constantly feeding 30kW into the LTO pack to keep it topped up. 30kW should be plenty for cruising at any legal speeds.
I've had a quick think and im sure there are plenty of details that warrant investigation with regards to not blowing up the boost converter on initialization, since the OEM application doesnt expect a DC voltage applied to the bus. But this doesnt seem to be the death of the idea to me, appropriate logic to make sure the bus voltage is indeed higher than the boost converter input before connecting up big contactors should be the idea.
If that does sound reasonable of an idea... my question is:
Does zombieverter VCU currently have implemented the control of the DC/DC converter? In particular i imagine i'd need control over the average current/power. Would prefer to utilise the control loops implemented in the OEM logic rather than DIY it.
And since this is my first post I'd like to thank everyone for all the time, effort and intelligence that has already gone into all these projects and to building this community.
