Page 1 of 1
Best inverter hardware to run a Remy HVH250?
Posted: Wed Jul 10, 2024 7:14 pm
by Mojave
I have a Borg Warner/Remy HVH-250-115-DOM motor and want to build up an inverter to run it. What is the best platform that Open Inverter supports that would be a good match for this motor? it's the 400V, ~200kW version.
I really don't know the different OEM platforms and what the strengths and weaknesses of each are. All my experience to date is with aftermarket programmable inverters.
Re: Best inverter hardware to run a Remy HVH250?
Posted: Wed Jul 10, 2024 7:30 pm
by johu
Nissan Leaf or i3 inverter might do it justice and is well hacked. Or if you can get ahold of a Tesla Inverter that should definitely pack enough punch
Posted: Wed Jul 10, 2024 8:41 pm
by Mojave
johu wrote: ↑Wed Jul 10, 2024 7:30 pm
Ideally I would like an inverter that will be completely environmentally sealed so I discounted the the Tesla LDU since it is not just integral, but the inverter housing is welded to the drive case. I looked at the SDU and at least that inverter bolts to the motor housing so it is possible but I figured the sealing of the HV phase cables would be messy. Neither the i3 or Leaf inverters have sealed phase outputs either so I guess that's just something I will have to address.
