LDU parameters to reduce power
Posted: Mon Aug 12, 2024 2:00 pm
by sirpewe
Hi.
Can someone please guide me a bit how I can change parameters to decrease power output?
My first idea was to use the current limit but this seems to set the inverter/motor in error state if triggered?
I would like to have the possibility to adjust the power output in a controlled way.
// Per
Re: LDU parameters to reduce power
Posted: Mon Aug 12, 2024 2:05 pm
throtmax, you can reduce it to limit max requested throttle which reduces power.
Posted: Wed Aug 14, 2024 12:03 pm
by P.S.Mangelsdorf
fslipmax also seems to reduce power. I'd check out the parameters threads and basically do the opposite of everyone raising power levels.
Posted: Fri Aug 16, 2024 2:46 pm
by Boxster EV
In the past when I’ve had OC events doing hard pulls (usually occurs during wheel hop), it’s fslipmax that I’ve backed off.
Not had one now in a few years. However, the firmware version can have a big influence too. I recently upgraded from 5.20 to 5.35 and the latter made the car a lot more powerful, even with an identical parameter file.
Posted: Sun Aug 25, 2024 4:19 pm
by sirpewe
Thank you all very much for the input.
tom91: I like the simplicity in this approach. I plan to send some can messages to be able to set different "power levels" and this should be easy.
Others: Will check parameters more for tuning.
