Commercial Box truck EV Conversion
Posted: Sat Sep 14, 2024 7:29 pm
Hello Everyone,
I'm thinking of putting a Model Y Performance motor in a commercial box truck.
I plan on re-gearing the drive unit to 3.54:1 from the stock 9:1 (see link one below). I'd then use a coupler to link both sides of the differential together (see link two). The output from the motor would then go into the truck’s differential, which has a reduction of 6.14. The truck also has much larger tires, measuring 1.06 meters in diameter.
According to my calculations, this setup would give the truck a top speed of 170 km/h with the motor at max RPM (18,500 approx). This is much lower than the Model 3/Y, which tops out around 260 km/h.
obviously 170km/hr is much too fast for a box truck. I don't plan on going much over 100 km/h, and the truck will be a lot heavier than the Model 3/Y, weighing around 15,000–20,000 lbs so having a bigger gear reduction would add to the low end torque...
My biggest concern is overheating and derating of the motors. Does anyone have any experience with Model 3/Y motors being used in continuous-duty applications?
For reference, the diesel engine in the truck has only about 200–250 hp.
I'd also mention, the truck is 4x4 an I plan on having two motors, one for the front diff and one for the rear diff.
Any thoughts of opinions would be greatly appreciated
https://amprevolt.com/products/tesla-mo ... 6062179380
https://amprevolt.com/collections/motor ... 6435477556
