Extend Inverter FAQ
Create a thread for each item that needs working on by the community
Has thanked: 378 times
Been thanked: 1558 times
Extend Inverter FAQ
Go through all threads with obvious questions and distill FAQ items from them. Put them here, trying to categorize the question with "Heading" style. E.g. "Leaf" (already exists), "Tesla" etc. Common questions go to.... Common :)
https://openinverter.org/wiki/Inverter_FAQ
bulletbug
Re: Extend Inverter FAQ
Post by bulletbug »
I'd like to suggest a few things as we start this area
* Let's avoid duplication by "assigning" ourselves a particular section simply by making a post with the name of the section you're working on
* Let's give an estimate of when we intend to complete the gathering of FAQ elements. This way the rest of the users will be able to see if something is fresh or gone dead.
* I suggest once you've finished your FAQ gathering...you post the resulting list back into your original post in a simple .txt file.
bulletbug
Post by bulletbug »
Tesla Small Drive Unit - is the area I'm working on.
I should have a compiled list of questions with some answers, by Feb. 26th.
I'll post the results as an edit to this post.
EDIT - I've attached an FAQ list. This was taken from the first 16 pages of the "Tesla Small Drive Unit Support Thread" up to the last post (as of now) Sun Feb 23, 2020 11:02 am
Anything marked with ***** needs answers.
I'm happy to do additional sorting or organizing on this section of the FAQ...Just ask.
TeslaSDUCAtegory.txt
(4.37 KiB) Downloaded 733 times
bulletbug
Post by bulletbug »
Tesla Large Drive Unit - is the area I'm working on.
Edit: I've reviewed the entire thread up to the last post on page 26 with a date of Sat Feb 22, 2020 7:49 am
I've marked areas within this documents with **** where someone like Damien, Kevin or Johaness to review or help answer. Once that has been done, let me know and I'll pick up this task again to start inserting it into the Wiki
TeslaLDUCategory.txt
(9.51 KiB) Downloaded 782 times
jerrykco
Has thanked: 117 times
Been thanked: 28 times
Post by jerrykco »
This is an awesome idea. I am new and trying to figure out what to do step by step. My focus is on Leaf Inverter + Motor not Tesla but obviously have a some of the same questions. Thanks for doing this. Maybe I can add to the Leaf Version as I learn more.
I confirmed with Johannes that he would like someone to work on the Leaf FAQ. I took it on....... :oops:
Jerry Kauffman
jerryk48 at gmail dot com
Has thanked: 235 times
Been thanked: 278 times
Post by P.S.Mangelsdorf »
As discussed in the Tesla LDU support thread, FAQ and Troubleshooting pages have been added to the Tesla section:
https://openinverter.org/wiki/Trouble_Shooting
https://openinverter.org/wiki/Setup_FAQ
Kevin Sharpe
Been thanked: 8 times
Post by Kevin Sharpe »
P.S.Mangelsdorf wrote: Tue Apr 14, 2020 7:38 pm As discussed in the Tesla LDU support thread, FAQ and Troubleshooting pages have been added to the Tesla section:
Many thanks :D
