NOOOO contactors no longer close! PCS teardown
Posted: Sun Oct 20, 2024 6:51 pm
by a900
Been working on a project using a Tesla model 3 battery pack connected to a solar inverter. Its been running for a few weeks but hit an issue. The contactors are no longer closing. Opened the penthouse to find a suspicious smell. Opened the PCS to look for damage and spotted what's in the photo and the smell coming from near the DC-DC pins corner of the board.
1092002-00f stamped on the casing. I don't consider myself as having the skills for a repair of the quality I would be happy with. I wondered if anyone has seen this before? or has any insights?
Re: NOOOO contactors no longer close PCS teardown
Posted: Sun Oct 20, 2024 6:58 pm
by Bigpie
Please attach photos directly to the post, click Full Editor & Preview and attach. Externally hosted photos can vanish in the future and make threads confusing. I've done so for you
Posted: Sun Oct 20, 2024 7:07 pm
by a900
Noted. I couldn't see attachments when I posted
Re: NOOOO contactors no longer close! PCS teardown
Posted: Mon Oct 21, 2024 6:26 am
by a900
More photos from teardown
Posted: Mon Oct 21, 2024 4:23 pm
by Doig5710
Sorry to see that happen, I'm not the best repair guy out there but would be saying it's probably a bit past it now, quite a few burnt bits there, multi layer board and it probably relied on it all being nice as a heat sink also?
Any idea what actually caused it to fail?
Posted: Mon Oct 21, 2024 4:48 pm
by P.S.Mangelsdorf
a900 wrote: ↑Sun Oct 20, 2024 6:51 pm
So the PCS has been running non-stop for a few weeks? What does your cooling setup look like?
Posted: Mon Oct 21, 2024 4:52 pm
What sort of 12V battery was connected? As the DCDC is susceptible to heavy voltage swings if not providing enough output/stabilisation with a battery.
Also the failure looks like cooking the pcb, possible heatsoak issue from lack of cooling.
Failure mode looks to be blown mosfet. More information is required on your setup.
Posted: Mon Oct 21, 2024 5:50 pm
by a900
Connected to a lead acid battery. Generally I would disconnected the PCS once the contactors had clicked in because of not having a circuit set up to handle the slightly higher voltage the PCS wanted to output. I noticed when the lead acid battery was connected to the PCS after contact to closing it would make a wine noise which would coincide with current flowing. I saw 50 amps being attempted to push into the battery.
Over testing I had the PCS connected and disconnected many times to cycle and test new code so on. Added to disconnecting the lead acid for long periods of time i wonder if the damage is down to my failings to provide what the PCS is happy with.
I wonder if others have seen similar and if we could find out what caused it.
Posted: Mon Oct 21, 2024 5:52 pm
by a900
tom91 wrote: ↑Mon Oct 21, 2024 4:52 pm
The board was not cooled but given that its out of the car and not using the charger side i doubt its overheating. The outer casing always been cool.
The set up has been following the GitHub battery emulator project.
